Cool Volt feature
Discussion in 'Chevrolet Volt' started by etyler88, Sep 16, 2008.
  1. etyler88
    etyler88 etyler88
    450
    Dover, DE
    Gotta admit that this is a cool idea.
    GM takes wraps off of Volt electric car | delawareonline | The News Journal
    The car, he said, will know a person’s normal route home, and if the driver veers off the route, it will calculate whether it needs to start the gasoline engine to recharge the batteries to extend the range, and for how long the engine needs to run.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    They're using On-Star for this feature...so it will require that you maintain your subscription for that to work (I would assume).
    I'm curious to see if Toyota files suit once this comes out...or if GM will seek to license the technology as Toyota has a patent on a very similar technology using GPS to optimize performance of hybrids.
  3. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    I believe this has been discussed as a possibility on EVs/PHEVs for a while. Most notable example I have seen is in the Project Better Place materials. I believe there have been discussions between PBP and GM, so maybe thats even where its coming from. PBP is primarily a network company, so their bread and butter is all this kind of software for BEVs and PHEVs.
    Better Place
    Rob
  4. Fibb222
    Fibb222 New Member
    1,499
    99
    This feature, that PBP has outlined is very cool. It would be fantastic.
  5. daniel
    14,487
    1,518
    Spokane, WA
    So the battery pack will hold 8 kWh. My Xebra goes 3 miles per kWh, but the Volt probably will weigh twice as much. However, it will probably have a more efficient motor than my Zebra. So let's say it gets 2 miles per kWh. That gives it an electric range of 16 miles. Weren't they promising 30? That would require it to get 4 miles per kWh, which I don't believe they'll manage to do.
    So it's going to cost $40,000 and only go 16 miles on a grid charge. Worthless. Assuming they actually go ahead and build it.
    And why do they need a GPS to decide whether to start the ICE??? Isn't the whole idea to go as far as you can on a charge before starting the ICE??? So why not just run it on the battery until the battery is too low, and then start the ICE?
    It's a scam, if you ask me.
  6. efusco
    19,891
    1,192
    Nixa, MO
    The sources I've seen say the Volt battery will be 16kWh capacity Daniel.
    The point of the GPS input is to start running the ICE if you know the battery will be depleted so that it can run within it's most efficient range and offer full power from the battery at all times rather than draining it low then demanding lots of power just as you hit the foot of the mountain you need to climb.
  7. daniel
    14,487
    1,518
    Spokane, WA
    So then Lutz was flat-out lying when he said in the interview that it would cost 80 cents to charge if you are paying 10 cents per kWh.
    In which case, what else is he lying about?
  8. bac
    bac Active Member
    863
    52
    Pennsylvania
    You name it.
    ... Brad
  9. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    He may not be lying. Even with a 16kWh pack, likely only 8kWh is allowed to be used in order to prolong battery life. So it will only need to charge 8kWh.
  10. daniel
    14,487
    1,518
    Spokane, WA
    You are referring to a specific characteristic of NiMH batteries: the kind we have in our Priuses. Lithium batteries behave very differently. You still may not want to take them down to zero, but they can use far more than half without compromising battery life.
    But even if they are limiting the battery to 50%, my point stands: Lutz's numbers are incompatible with the claimed specs.
  11. rgathright
    rgathright New Member
    I doubt GM will give us a more efficient electric motor.
  12. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    There's me thinking the Volt will not be able to charge the battery using the ICE...
