Coolant Flow Control Valve (Air heating issue)
Discussion in 'Gen 2 Prius Technical Discussion' started by Cloaked, Nov 12, 2007.
  1. Cloaked
    Cloaked New Member
    My heater is not working too swiftly in my 2005 Prius, and I am starting to get cold feet in the morning. I just hit 46k on it and took it in to Toyota to review a couple problems.
    After running a $49 diagnostic test on the car, I was infomed that I need a $400 coolant flow control valve.
    Obviously my main question is whether this is a costly proposition, can I get a valve somewhere else and are these codes accurate to the issue at hand (P1121, P1150, P1151, P1161)?
    Thanks for any feedback on this!
  2. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    p1161 isn't showing up but the rest sure point out the valve in question.
    unfortunately, there's not a lot you can get aftermarket for these cars yet. doing this on your own is risky because getting air in the coolant loop is NOT good. $400 sounds reasonable for parts and install.
  3. Cloaked
    Cloaked New Member
    The $400 was only for the part. An additional $200 for the labor.
    The part is #16670-21010, and your correct about finding an after market, I can't find it anywhere.
    The Toyota tech was kind enough to give me all this information...
  4. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(Cloaked @ Nov 13 2007, 09:39 AM) [snapback]538844[/snapback]</div>
    Check back with them. $400 sounds like the whole job, the valve is only $66.47 list price. Try Hoy-Fox with your part #:
    http://www.trademotion.com/partlocator/ind...amp;catalogid=2
    (I tried to post a direct link to the part#, but it didn't work.)
    - Tom
