Coolant Flow Control Valve Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mazenkordi, Jun 9, 2017.
  1. mazenkordi
    mazenkordi New Member
    jordan
    Toyota prius 2009 i have the code p1121
    i changed the coolant flow control valve twice and after reset the check engine light after one or tow days maximum i see again check engine light with the same code p1121 please help me. what is the problem?
  2. Patrick Wong
    18,200
    6,493
    What process did you use to get air out of the engine coolant loop? It is likely that air remains in the system.
    How well does the cabin heater work?
    m.wynn likes this.
