Coolant in transmission oil
Discussion in 'Gen 3 Prius Technical Discussion' started by ptrustfull, Feb 9, 2026 at 4:28 PM.
  1. ptrustfull
    ptrustfull Junior Member
    23
    Suriname
    2012 Aqua
    I am resurrecting a 2010 Prius. Drove in high water about 3 years ago and did not want to start. Is running now. I thought water might also have entered the transmission trough the breathing hole so i took out the transmission oil. There was some mark of water in it. I rinsed the transmission with some clean WS but it seemed like now there is more coolant (pink Toyota type) in the oil. Is this possible? i have looked at the diagram and the transmission is cooled on the side of the inverter. The only place that water might go into the transmission oil is in the transmission. Is this something that happens?
