Coolant or battery replacement
Discussion in 'Gen 2 Prius Main Forum' started by Greg1780, Feb 11, 2019.
  1. Greg1780
    Greg1780 Junior Member
    Greg1780Junior Member
    I have a 2008 Prius that I purchased new almost 11years ago, it now has 160,000 miles and it’s been a gem of a car.
    Suddenly the heat output is at (half heat) and all the fluids are full.
    Also, the display screen shows the electric is generating only 1/2 to 1 vehicle, (50 watts) o the screen.
    Q: Does this normally mean the main battery is about to go bad.
    Thank you
    Greg
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    How well the heater is working has nothing to do with the battery. Check the coolant level in the radiator when the engine is cool. Also turn the car on and take the cap off the inverter reservoir, you should see coolant circulating in there.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,374
    3,228
    Madison, Wisconsin
    And after 11 years it is time to buy some diagnostic equipment.
    Raytheeagle and SFO like this.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Please include you location so that you can receive better input on your perceived problem(s).
    If you live in an area that is experiencing extreme cold (under 0C/32F), you may find the heater lacking at best. The MPG will also suffer.
    Do you notice anything else on the display screen, like when you park with a full HV battery and then upon restarting its nearly empty?
    Raytheeagle likes this.
