coolant pump replacement and other ???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tigerpilot, Jun 2, 2014.
  1. tigerpilot
    tigerpilot Member
    141
    Naples FLorida
    Hi:
    My 2009 had the pump replaced under warranty. Going on 100,000 miles and I'm wondering if the dealer changed the coolant when they changd the pump?
    Also.... although the car runs great, do you think I should change the spark plugs.
    I changed the transmission fluid at 30,000 miles.
    I appreciate your comments.
    Thanks, Don
    #1 tigerpilot, Jun 2, 2014
  2. KhaPhoRa
    KhaPhoRa Member
    168
    37
    I would guess they did change the fluid but you shoud probably call them and ask.
    Regarding spark plugs, would you rather prevent an issue or respond to one after the fact? If it were me I would change them now. I'm assuming you meant yours is a 2007.. If so it's a pretty simple job.
  3. tigerpilot
    tigerpilot Member
    141
    Naples FLorida
    No...It's a 2009. I lost a decade somewhere.
    Don
  4. KhaPhoRa
    KhaPhoRa Member
    168
    37
    That happened to be back in the 90s :) 2009 is easy as well.
