Coolant recovery wiring
Discussion in 'Gen 2 Prius Technical Discussion' started by Cory151, Jul 9, 2015.
  1. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    Hey gang I was replacing a fender liner that was damaged from running over a box when I noticed there was some shoddily repaired wiring on the coolant recovery tank. Does anybody know what this green wire hooks to?
  2. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    Looks like the green one and the white one with a black stripe have been cut. I notice that on this particular car when I power off I do not hear the pump run like my others. Is this why? I soldered the connections and heat shrank them as they were just twisted together and taped.
    Unfortunetly I'm without another Prius to compare the wiring to, at this time.
    #2 Cory151, Jul 9, 2015
  3. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    I tested the pump by applying 12v from an external source and it seems to work just fine.
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    John
