Coolant refill after engine overhaul
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kolez2000, Dec 20, 2021.
  1. kolez2000
    kolez2000 Junior Member
    64
    West Africa
    Hello, I just overhaul the engine on my Prius 2005 yesterday. I wish you know the process of filing the coolant. I know in this part of the world, we wait for the engine to heat up before adding coolant, can we apply the same system to the Prius system? Or I need to fill with coolant before I start the engine. Pls I need this information as I about to start the engine in 8hrs time. @bisco
  2. ChapmanF
    17,347
    It is best to fill first, as well as you can, then continue to add coolant as air escapes while warming the engine.
    By searching this site you may be able to find a download of the repair manual, or perhaps just of the section in the repair manual for coolant refill. That would put you in the best position for a successful outcome, and you can be looking at the manual without having to wait for someone writing a description. The process is somewhat elaborate for getting all the air out, and the repair manual will show you the details.
    Fred_H and SFO like this.
  3. kolez2000
    64
    West Africa
    Thanks for your response
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    The struggle with a full coolant dump is air will get trapped in the coolant thermos. This makes it very difficult to bleed.
    It is very important especially for you that you monitor engine temperature during this process. This engine has a aluminum head and will not tolerate an overheat. Since no dash temp gauge it requires an OBD code reader that will read engine temp during this process.
    what must happen for correct bleed process is to manually run the thermos bottle pump that way air trapped will be pushed along to the rad with the cap off and front end highly elevated. Front end elevated higher than rad top higher than the engine head as air gets trapped in there too.
    Bottle motor is manually run by removing its relay and using a jumper wire turn on that pump at intervals with engine running in inspection mode.
    aGo on YouTube search
    Prius inspection
    it will show you the chicken dance to get the engine to run in inspection mode
    Where engine idles continuously.
    Good luck this job sucks.
    Fred_H likes this.
  5. Mendel Leisk
    40,584
    Here's repair manual info:
    Fred_H likes this.
  6. Aegean
    Aegean Active Member
    454
    203
    Alexandria VA
    Fred_H likes this.
  7. ChapmanF
    17,347
    I bought one and still have it, but have gone back to filling and burping the old fashioned way, which hasn't really been any more trouble, and doesn't need me to lug a compressor out.
    There are some subtleties if you go the vacuum tool route. Make sure your coolant supply jug is above the system, and that your tube from the jug to the fill fitting is already free of air. If the capacity is more than one gallon jug, combine the coolant first in a bigger jug, or watch like a hawk not to suck any air at the end of jug 1. Plan on no do-overs. If you get a partial fill on one attempt and then you try to start over with vacuum, the volume decreases as the hoses collapse and your partial fill sprays out the venturi. So a do-over means you drain the system again, then do over.
    On the bright side, i have found the vacuum venturi handy for lots of other stuff.
    Fred_H likes this.
  8. Fred_H
    Fred_H Misoversimplifier
    558
    481
    28
    Germany
    The euro spec Prius does not have the coolant thermos, so it is possible that his Prius also does not have it. That makes it easier, but it still takes a while to get all the air out. Just a reminder, carry on.
  9. Aegean
    454
    203
    Alexandria VA
    What other differences the Gen 2 European Prius has? I have noticed that the steering wheel right buttons are not there. I also read that there are disks on rear brakes.
  10. Fred_H
    558
    481
    28
    Germany
    Steering wheel buttons depends on trim level and options. I think I have pretty much everything and all the same buttons.
    It has rear disk brakes, and also rear drum brakes which are used only as parking brakes, actuated only by cables.
    It does not have the eccentric mechanism on the windshield wiper.
    It has simple halogen H4 bulb headlights.
    It has an "EV" that button prevents the gasoline engine from running under certain, very limited, conditions. (warm engine or press within 10 seconds of cold start, max 50 km/h, low power demand, battery not too low or too cold, etc..)
    It does not have an instrument lighting dimmer wheel. It toggles through 3 brightness settings by pressing the rightmost button under the touchscreen.
    It has only the normal main engine air intake filter, not the second, additional, charcoal filter in the air filter housing.
    Probably a couple more things I can't remember at the moment.
    Aegean likes this.
  11. kolez2000
    64
    West Africa
    Thanks
  12. kolez2000
    64
    West Africa
    Thanks for the info
