coolant warning light question
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by bkepler, Aug 1, 2024 at 12:05 PM.
  1. bkepler
    bkepler New Member
    SW Pennsylvania
    2013 Prius v wagon
    Finally joined, trying to do more things myself. I did the egr pipe, valve and cooler cleaning. After it was back on and I added some coolant, I started the car and the coolant light was on and hasn't gone off. I checked the coolant temps via my obd2 reader app on my phone. It shows what appears to be normal/good temp range even when driving and a/c on.
    Had thought I possibly did something to the temp sensor, but the readings look good though. Are there more than 1 temp sensor for this light? Any ideas appreciated, thanks.
  2. rjparker
    rjparker Tu Humilde Sirviente
    8,022
    4,756
    Texas Hill Country
    There are two temp sensors, one on the drivers side of the engine under the egr and the second on the exhaust recirculation hose next to the master cylinder.
    #2 rjparker, Aug 2, 2024 at 7:27 AM
    Brian1954 likes this.
  3. Mendel Leisk
    38,773
    If you haven’t: be sure to clean intake manifold too; it has EGR passages. See top two links in my signature for more info (on a phone turn it landscape to see signatures).
    what’s the miles?
