  1. PixelRogue
    317
    57
    US
    Today some smoke (vapor) started exiting a temperature vent above the radio. Various testing would state the smoke was only present when the outside vent mode was on, and most times after acceleration.
    Pulled over, popped the hood and noticed low coolant in the reservoir closest to left of engine (while facing engine from outside, in front of passenger seat). Swung by a Toyota dealership, picked up some replacement coolant, topped it off and car is back to normal. Simple, easy stuff.
    In some of the googling and videos and such, noticed references to flushing the coolant, as it needs to be replaced about every 100,000 miles or so. Other than a guess in terms of 'for good measure' or 'its about time' preventative maintenance, how would one 'know' (for certain) the coolant fluid would be bad, in need of replacement?
    I am handy enough to drain and refill...albeit getting under the car will be a pia.
  2. Mendel Leisk
    38,709
    Watch the level on the reservoir for a week or two. If it continues to drop, could be failing coolant hose, radiator damage. Or head gasket failing.
    How many miles on it?
  3. Mendel Leisk
    38,709
    First engine coolant change is slated for 100K miles or 10 years. First inverter coolant change is 150K miles or 15 years. Thereafter, both are 50K miles or 5 years.
    Greenteapri likes this.
  4. PixelRogue
    317
    57
    US
    120k
  5. PixelRogue
    317
    57
    US
    I was thinking of doing them together at the same time, given everything is already there and open...might as well do both?
    I will keep an eye on the levels.
    How do you know when the coolant itself has gone bad though? So there are estimated time frames for a change...curious how you know when it has spoiled.
  6. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Coolant doesn’t just vent out of your car unless there’s a leak or a serious overheat event. If there’s no leak when the engine is hot, maybe the leak is in the heater core, which means it will leak when the heater is on.
    If it seems ok... proceed with care until you’re sure the problem doesn’t return. Monitor the coolant level at least daily.
    As for a coolant flush, I think you should wait two weeks, to be sure you don’t have a leak.
    RMB, The Critic, jerrymildred and 2 others like this.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    PixelRogue and Rebound like this.
  8. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    If you are getting vapor from the interior vents, this may point to a leak in the heater core. If this is the case, you wil also get a slimy/sticky buildup on your interior glass from the glycol.
    mjoo likes this.
  9. Rebound
    3,964
    2,613
    Portland, OR
    That’s what I was thinking... which explains why the problem went away... it’s summertime and hot out. He isn’t using the heater.
  10. AzWxGuy
    AzWxGuy Weather Guy
    982
    495
    Tucson, AZ
    2021 Prius
    If it is a heater core leak (sounds likely), wouldn't the heater loop continue to be pressurized similarly to the ICE cooling loop and therefore continue to leak? Unless of course there are two valves controlling the heater loop flow, which I doubt but don't know for sure. The only other time I've seen vent vapor such as this was under high humidity air intake from outside, which the OP does state sans any statement about humidity (location is US which could be anywhere), and initial air conditioner operation. After a while the interior air is cooled and de-humidified enough to eliminate vapor condensation from the vent.
    CR94, mjoo and jb in NE like this.
  11. Mendel Leisk
    38,709
    #11 Mendel Leisk, May 31, 2019
  12. PixelRogue
    317
    57
    US
    So let's say there is a heater core leak,
    Yesterday was the first notice of any vapor through a vent; have not noticed any signs of issues (no build ups on window during cold weather. Discovered a rather low coolant reserve when popping the hood. Added OEM SLL coolant and everything was normal afterwards.
    Currently monitoring levels to determine if there are any leaks.
  13. Rebound
    3,964
    2,613
    Portland, OR
    Did you turn on the heater?
  14. 2014
    2014 Member
    30
    31
    MA
    Did you have the AC on? Was the humidity high? Could have been cold AC air causing warm humid air to condense into visible vapor. Low coolant level may be a coincidence and have nothing to do with it.
    jb in NE likes this.
  15. Mendel Leisk
    38,709
    Ok, this is completely off the wall, but am I the only one thinking your user name is MARTINI, and you joined in 2014.
    Good coffee...
    Grit likes this.
  16. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Those are my moments here also but with dark red wine.
    RMB, Greenteapri and Mendel Leisk like this.
  17. Mendel Leisk
    38,709
    Or a martini.
  18. PixelRogue
    317
    57
    US
    Remaining hopeful that that the low coolant would be a coincidence.
    At the same time, winds are pointing to a coolant leak. I topped off the coolant on Thursday (and would wait for the liquid to settle at the high level mark in the coolant reservoir (located left of engine, in front of passenger seat.))
    Had some long drives since Thursday... placed about 400 miles, 1/2 would be highway. Today, I notice the coolant level at the 'low' level mark. Only disparity I can think of would be a warm engine when coolant was added, cool engine this morning.
    So, I am monitoring for a coolant leak.
  19. PixelRogue
    317
    57
    US
    Thinking ahead (while hoping there is no leak) ~ how would you actually identify the source of the leak itself? I have not yet seen any liquid on the ground to even know what quadrant of the engine to start looking. A few tutorials are about replacing
    Possibilities:
    - coolant flow control valve
    - water pump
    - heater control
    - thermostat
    - cracked hose
    Stating the obvious, yet putting in writing helps think through the issue.
  20. Mendel Leisk
    38,709
    Add head gasket failure to that list. Check through the spark plug holes with a boroscope, and/or leak-down test.
