Cooling Down Sound
Discussion in 'Gen 3 Prius Main Forum' started by bnaccs, Mar 22, 2011.
  1. bnaccs
    bnaccs bnaccs
    191
    Colorado
    I just started to notice that my Prius makes weird sounds when I first pull in the garage and turn it off. It is almost like an electrical sound, or bees buzzing, or water boiling with a lid on the pot, instead of the normal ping and pop that some cars make when cooling down. The sound goes away in a few minutes. This is when the car is completly off. It does make the occasional ping sound like a normal car from time to time when cooling off.too. Has anyone else noticed this with their Prius?
  2. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Yup, it's normal according to the owner's manual. Actually, there's another sound at about an hour later which is fuel vapor check. You should also hear "bees buzzing" when you open the driver's door after the car's been shut off for a while. One time I heard a screaming sound when I closed the passenger door, but it was me screaming when I closed the door on my finger!
    Read the owner's manual for complete details and descriptions of sounds.
  3. Mark57
    2,945
    2,736
    OK
    Tom nailed it. It's normal.
  4. lovingUcbog
    lovingUcbog New Member
    Cambodia
    like the screaming sound part
  5. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The "sound" after shut down (not the screaming :D) is one of the four Prii coolant pumps running:
    1. ICE coolant pump - a mechanical pump in a Gen2.
    2. Inverter Coolant Pump - an electrical pump that is the subject of a free replacement recall in older Gen2 Prii.
    3. Thermos coolant pump (this is the "sound"). It runs at shutdown and start-up to conserve heat energy in a Gen2.
    4. Heater coolant pump (keeps you warm in cold weather).
    JeffD
  6. bnaccs
    bnaccs bnaccs
    191
    Colorado
    Thanks so much. I read the owner's manual but missed thepart on right after shut down. I hear th esound when opening my door, and then the evap. check about 5 hours later, but the sound I explained was new to me. Glad it's a normal sound. I love m ycar!
