Cooling fan computer.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Scootb73, Apr 6, 2025.
  1. Scootb73
    Scootb73 Junior Member
    canada
    Hi,I have a 2013 Prius C(obviously)
    I started getting problems with overheating and losing coolant,heat from only one vent.
    Fuses are good
    Relays are good
    No leaks
    Head gasket is good
    changed Radiator cap
    New waterpump
    New thermostat
    Radiator fan comes on when directly wired to battery only.
    I have an obd2 temperature gauge so the temperature sensor must be good.
    I am left thinking that it is part number 8925712020 cooling fan computer that is the issue.
    Any cheap sources for one of these?
    I’m gonna try the nearest scrappy next weekend if it’s still there,but I haven’t seen too many C’s around here(Edmonton Alberta).
  2. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Is there any indication of overheating errors?
    Why did you decide that the fan control computer 8925712020 is faulty?
  3. BiomedO1
    BiomedO1 Senior Member
    2,813
    1,493
    SacTown, Ca
    Your overheating; losing coolant; no leaks - I believe a bit more troubleshooting is required with a better scanner.
    Re: OBD2 temp gauge, how do you know the sensor is accurate or the gauge is setup properly? Have you used an IR temp gun to verify?
    I'm just asking questions......
    #3 BiomedO1, Apr 8, 2025
  4. ChapmanF
    17,326
    A lot more ways to get a bogus reading with an IR gun than with the car's own thermistor and an OBD tool.
    Of course if the car's reading really doesn't make sense (isn't close to ambient with engine cold, not rising plausibly as engine warms) it can be worth checking the sensor and wiring with an ohmmeter.
    The sensors are ordinarily pretty trouble-free.
  5. bisco
    51,139
    coolant has to go somewhere
