Cooling performance of the hybrid battery is low consult a dealer
Discussion in 'Gen 3 Prius Main Forum' started by Allison Meggison, Dec 21, 2019.
  1. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    I cleaned the cooling fan after this prompt and now my car won’t start . It says maintenance required soon and usually says that when I need an oil change I thought but yesterday I had my oil changed and got the light several hours later. I have a 2013 Prius with 255,601 and a newer engine with about 65 k
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,209
    5,902
    Columbia, SC
    Did you touch anything other than the fan? Did you disconnect any plugs, wires or safety disconnect?
    Raytheeagle likes this.
  3. hill
    8,167
    Did you try to reset the maintenance required soon / idiot light? It's the same process most likely.
