"Cooling performance of the hybrid battery system is low" message won't go off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jimmyewilso, Jul 25, 2021.
  1. Jimmyewilso
    Jimmyewilso New Member
    Nashville
    I have the "cooling performance of the hybrid battery system is low, consult a dealer" message on my 2014 prius. I have cleaned the intake filter on the rear passenger side (it was dirty). I have inspected the hybrid battery fan and it is clean. I've have scanned the system and it is not providing any other codes that would suggest an issue.
    I was hoping that cleaning the intake filter would take care of the this, but i can't get the hybrid battery message to go away. I have unplugged the 12 volt battery, and the message is still there. Could there be a larger problem with the hybrid battery? If not, how do i get rid of this message?
  2. Tideland Prius
    16,146
    Have you changed the inverter coolant? Or checked the coolant lines? (Separate from the engine coolant).
  3. Mendel Leisk
    38,707
    How many miles?
  4. ChapmanF
    15,566
    The hybrid battery system is air-cooled; the inverter coolant loop doesn't run all the way back there.
    Tideland Prius and Mendel Leisk like this.
  5. PriusCamper
    PriusCamper Senior Member
    11,092
    4,515
    Pacific Northwest, USA
  6. Jimmyewilso
    Nashville
    142k
  7. Jimmyewilso
    Nashville
    no, i have not. Thanks! i will look into this.
  8. bisco
    49,440
    have you cleaned the battery itself? can get pretty bad in there
  9. Jimmyewilso
    Nashville
    This is great advice, thanks. I just ordered one today. Would the "cooling performance" message go off by itself once I have cleaned the cooling system or does it always need to be reset?
  10. PriusCamper
    11,092
    4,515
    It's probably different for gen3 than gen2... My experience with this problem in Gen2 is some corrosion in one of the plugs that powers the cooling fan. That's probably not the issue in Gen3 though.
