Cooling performance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groundpounder17, Jun 22, 2019.
  1. Groundpounder17
    104
    77
    AR
    So I rebuilt my engine of my 2015 and it’s been running well, but today I had a message pop up on my car that states “cooling performance of hybrid battery is low consult dealer”.
    Does this mean I need to clean my cooling fan? Is this common?
  2. Tariq87
    Tariq87 Member
    87
    28
    jordan
    https://priuschat.com/index.php?threads/142998/
  3. Mendel Leisk
    41,865
    Probably. @NutzAboutBolts has a video on it, #21 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    One thing, he pulls off the rear seat bottom: I wouldn't bother with that, just push apart the seat and back cushions at the inlet grill and reach through with a 12mm socket on an extension with ratchet.
    Also, I found it possible to clean the fan without completely removiing it. Just used q-tips between the blades. Then blew it out, and the whole area, duct work and so on.
    There are fasteners that hold the hatch floor atop the hybrid battery that are hard to break loose: I left most of them off at reassemble, made it easier next time.
    NutzAboutBolts and Greenteapri like this.
  4. Groundpounder17
    104
    77
    AR
  5. Groundpounder17
    104
    77
    AR
    Thanks. I’m guess I have a project for tomorrow
  6. Tariq87
    Tariq87 Member
    87
    28
    jordan
    It's very common if you have pets..
    Clean your hyprid fan and everything will be fine
  7. Groundpounder17
    104
    77
    AR
    Thanks everyone. I drive my car for work and when the warning appeared I was worried my hybrid battery is going out.
    My pets haven’t rode in my car much but I have kids and they keep it pretty dirty back there. I’m sure with 225,000 miles it’s all pretty dirty
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    With that many miles and having kids. I'm sure it's dirty, too. :D
    Cleaning the fan is a fairly common chore depending on who or what is in the car with you.
  9. Mendel Leisk
    41,865
    I put a piece of household window screen on the back face of the inlet grill, held in place by a couple of loops of thread. I periodically check it with a good light, figuring if it's starting to look dusty it's time to revisit the fan cleaning.
    CR94 likes this.
  10. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    That's such a good suggestion that I did exactly the same a couple of years ago, except using glass HVAC filter material. There is never much to see in it.
  11. Groundpounder17
    104
    77
    AR
    I’ll be doing the cleaning tomorrow. I watched video. It shouldn’t be too difficult
    RMB, jerrymildred and Mendel Leisk like this.
  12. Groundpounder17
    104
    77
    AR
    I have already done this cleaning but I never have figured out how to clear the warning from the display. I did an oil change today and when I reset the maintenance alert I thought it would clear the “cooling performance of the hybrid battery is low consult a dealer” alert but it did not. Anyone know how to reset this?
  13. ASRDogman
    ASRDogman Senior Member
    7,794
    3,976
    You should get this filter. Got the larger filter from Toyota, and the other is a/c filter from home depot or lowes...
    I just wash it with water once a month and let it dry.
  14. Groundpounder17
    104
    77
    AR
    I take it the Toyota filer is better.
    How do I clear the warning? I took it to o’Reilly’s and they scanned it and it didn’t show a code but the warning is still there
  15. ASRDogman
    7,794
    3,976
    It is a Toyota filter! That's the Toyota part number.
    But I added the foam filter because I have dogs. Lot's of FUR and dust.
    The Toyota filter alone would not be enough.
    You need TechStream, probably.
  16. Groundpounder17
    104
    77
    AR
    Thanks. I’ll try to find somewhere that has techstream to clear it and I’ll get both filters.
  17. ASRDogman
    7,794
    3,976
    I must of misread your reply. The non-foam filter is from Toyota. It snaps into place over the vent on the rear passenger pillar.
    I cut the foam to fit between the pillar and Toyota filter because it will catch the fur better. And it's not restrictive.
    I've had it on for almost 2 years and the battery has never over heated and I've never heard the HV Battery Fan.
    #17 ASRDogman, Jul 27, 2019
  18. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    HV battery never goes above 80F during the summers for me.
  19. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Techstream did the trick when my friend had the same warning light.
    Raytheeagle likes this.
