Cooling System Maintenance?
Discussion in 'Gen 2 Prius Technical Discussion' started by wlai, Jan 30, 2020.
  1. wlai
    wlai Junior Member
    36
    Pacific NW USA
    Not sure if it's just me but I have not seen/heard too much discussion about the cooling system. I am coming up on 190K and haven't noticed anything wrong about the cooling system, both the engine and the inverter, and don't think anything has ever been done about it. Haven't even tested the coolant to be honest.
    My prius is a 2008 and I took it over around 2015, and I don't know if anything such as water pump or flushes have ever been done. Is this a case of "ain't broke don't fix it" or "better get on it now"?
    52,409
    it's just you:)
    52,409
    better get on it now. start by entering your vin in the owners website to see maintenance history, then complete everything in the schedule that hasn't been performed.
    ydpplqbd and wlai like this.
  4. wlai
    wlai Junior Member
    36
    Pacific NW USA
    Does Toyota have a site to check against for service history? Wasn't aware of such a service!
    ydpplqbd likes this.
  5. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    It's www.toyota.com/owners, and you can check there for its maintenance history. Also, if you're DIYing, I have some pictures I can post that should make it significantly easier to find the drains. There are three of them.
