Copying the metal key
Discussion in 'Gen 4 Prius Accessories and Modifications' started by roadwarrior28, Sep 25, 2017.
  1. roadwarrior28
    roadwarrior28 Member
    68
    69
    Portland, OR
    Three Touring
    Can the metal key be taken to a hardware store type place and be copied with their machines? Anyone know what the easiest way to get an extra copy of the metal key (on a regular key) is?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Probably more of a specialist locksmith - they're called "Internal cut key" or "laser cut key" - I checked around here and didn't find a locksmith who did them. Unlike the old double-sided type, they're apparently a tighter tolerance too, so fudging one up yourself would possibly be difficult or impossible.
    pilotgrrl and RCO like this.
  3. Prodigyplace
    12,682
    11,832
    Central Virginia
    The key would also be of little use without a fob. It would just permit opening the front doors.
  4. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    My first post!
    We can cut them in my shop. Not sure about the key blanks though as it is only cut on one side and therefore fairly thin.
    pilotgrrl, RCO, krmcg and 2 others like this.
  5. Prodigyplace
    12,682
    11,832
    Central Virginia
    Welcome to PriusChat!
    I hope you enjoy driving your Gen 4 Prius.
    pilotgrrl likes this.
  6. alanclarkeau
    7,045
    7,593
    Or - locking the doors but leaving the car POWERed up. Not super secure, but it works for ducking into the corner store if you want the A/C to run while you're there.
    pilotgrrl, RCO and roadwarrior28 like this.
  7. Prodigyplace
    12,682
    11,832
    Central Virginia
    You would remove the physical key from the fob first. You need a physical key to lock the doors in that situation.
  8. roadwarrior28
    68
    69
    Portland, OR
    Three Touring
    I work as an Uber driver and appreciate the door locked/engine on feature to preserve cabin temperature. It's just a pain in the nice person to keep pulling the metal key out of the fob, so I was looking to get a copy so it could just be on my keychain.
  9. bisco
    52,396
    i thought i read home depot, but not positive.
  10. Prodigyplace
    12,682
    11,832
    Central Virginia
    Perhaps search the threads of those who have bought additional fobs. I though I read most locksmiths could cut the key. I am not sure about blanks, though. That might be a dealer parts item, if it is available.
  11. El Dobro
    El Dobro A Member
    7,093
    3,271
    I would imagine the dealer has to be able to cut them.
  12. bisco
    52,396
  13. Prodigyplace
    12,682
    11,832
    Central Virginia
    Some fobs there have blank keys IIRC.
    RCO likes this.
  14. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Normally "laser" cut keys are cut on both sides. The fob key is single sided. I suspect this would cause a problem for some machines, and blanks would likely not be readily available. I'm sure I could come up with one (or make one) if necessary.
  15. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Made a key blank today. Haven’t cut it because the machine I want to use is in one of our other shops.
    Maybe this weekend.
  16. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    @Locksmith, please let us know how it works out!
    RCO likes this.
  17. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Well, I didn't get there! I have a week at work and then I'm off on vacation for 2. It isn't looking promising at the moment.
  18. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Ok, first day of my 2 week vacation and I go to work! Had to pick up an expense cheque, so it was worth it.
    I took my manufactured keyblank (from a safe deposit box blank) and cut it on one of our laser key machines. Works like a charm!
    Not sure if the picture is showing, so I inserted a link to the picture as well.
    https://1drv.ms/i/s!Aq6OwnuXHY4KgYMIW-mHPfUVNwDQ_w
    Prodigyplace likes this.
  19. Prodigyplace
    12,682
    11,832
    Central Virginia
    Here is the photo.
  20. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    So, what did I do wrong in posting the picture?
