copying the telephone numbers
Discussion in 'Gen 2 Prius Audio and Electronics' started by lynn43, Dec 29, 2005.
  1. lynn43
    lynn43 New Member
    <_< I have successfully set up the computer to recognize the bluetooth in my blackberry, yet I am having a hard time getting the computer to copy the phone numbers from the blackberry to the Prius (05).
    I was told the blackberry may be a very secure system (used by the US goverment employees). Does anyone else have this problem?
    When I try to copy the bluetooth disconnects from the system.
    Here what happens when I try to copy:
    1. I do not get the sceen that allows me to copy or overwrite
    2. The Prius says it it copying, but disconnects bluetooth instead.
    I am thinking I should have copied the telephone numbers when i typed in the address for the blackberry (the orginial set-up). Maybe I should delete the blackberry and start over with the setup.
    blackberry is T-mobile 7105
  2. infohwyguy
    infohwyguy New Member
    33
    Swedesboro, New Jersey
    I have the exact same symptom with my Cingular Samsung D307. No solution yet. I hope someone here knows how to fix this problem.
  3. kpauley
    kpauley New Member
    149
    Gilroy, California
    The BlackBerry, and some other phones out there, so not support a push of the addressbook to another device via BT. Some devices will only support single address book entry transfers at a time which is fairly painful.
    There is another thread that explains how to transfer from your laptop to the Prius, you need to setup the file ahead of time and you can transfer it over. I'm not sure if it works for the 2006 or not.
    The thread can be found here: Laptop transfer
    Ken
  4. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    There is also a PDA procedure HERE.
  5. lynn43
    lynn43 New Member
  6. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Thank you too! You are the first person that has posted an interest in the procedure, so that's certainly nice! :)
