Correct voltate for 12v battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by f18cmech, Nov 21, 2018.
  1. f18cmech
    f18cmech Junior Member
    52
    San Diego
    Hi all,
    I think my 12v battery maybe on its way out, the keyless system no longer works and I'm readint 12.45 volts with a volt meter with the car off. Would you say this means this battery could stand to be changed? Thanks.
  2. audiodave
    audiodave Active Member
    798
    269
    US
    That's not a terrible voltage. Turn the headlights on and see what it reads.
    Change battery in your key?
  3. Mendel Leisk
    40,582
    I think I've gotta stay away from battery threads.
    bisco and 05PreeUs like this.
  4. f18cmech
    52
    San Diego
    Yes, key battery changed, and it worked sporadically for a couple days but now it hardly works at all. When I go into diag mode, not in ready mode, it says 11.9, drops and holds at 11.4 with lights on, goes back to 11.9 when off. However a battery test showed it only had 150 CCA out of the 325, and read 12.45 volts.
  5. f18cmech
    52
    San Diego
    Why?
  6. Mendel Leisk
    40,582
    They're addictive, lol. That CCA is bad, think it's the clincher: time for a new one.
  7. audiodave
    798
    269
    US
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    D.O.A.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    The additional readings that you provided definitely indicate a 12 V battery on the way OUT.
    Time for a replacement.
    You also need to manually check the voltage while the car is ON, in READY mode, to be sure it is charging properly.
  10. bisco
    51,154
    how old is it? that's one of the few times low cca has been reported here
    audiodave likes this.
  11. f18cmech
    52
    San Diego
    It was changed at 98k and now the car has 222k. Far more than was changed the first time. But, the alarm seems to work when it wants. Not sure why, but sometimes will work when battery is at 12.1 but other times not. I'm thinking its not the battery, unless low voltage will result in the alarm working intermittently. Any thoughts?
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    A new 325cca Prius 12v battery will usually test at 425ish.
    You're heading toward being broken down somewhere due to a failed 12v battery. Regardless of your problem, you need to replace it. Odds are reasonable, after fixing the obvious, the other problem will probably resolve itself.
  13. sam spade 2
    7,035
    2,799
    2017 Prius c
    Yes it will.
    You should be focusing on finding out why the battery reads 12.1.
    It should NEVER be that low.
    Odds are that the battery is just getting weak.
