corroded Alloys?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by StuartS, May 24, 2006.
  1. StuartS
    StuartS New Member
    34
    Carlisle, UK
    There have been several cases reported, in the UK, of corroded alloys on post 2004 Prius. Various causes have been suggested including corrosion from brake dust to poor lacquer to seal the wheels.
    I would be interested to know if this problem exists on the US cars as Toyota seems to be taking forever to sort out what is an incredibly simple problem. Come to think of it Lexus has the same problems too.
    It's not often anyone can say that Toyotas have a problem, but it's doubly irritating that all the other manufacturers seem to perform better than Toyota on this issue.
    Stuart S :angry:
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Stuart, you have a different size and possibly make of wheels on your UK Prius. I have never heard of any corrosion problem with US/CAN wheels.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I haven't heard anything specific about the Prius or Toyota cars, but alloy rims in general have problems with corrosion. Aluminum is a soft, highly reactive metal. What keeps it from fizzing away almost immediately is that Aluminum oxide is very tough (chrome works the same way). The outside layer of the wheel oxidizes into a tough, corrosion resistantent layer. If you scrape off that layer, or prevent it from forming, then the Aluminum underneath is exposed to corrosion. That's the problem with sealing Aluminum with a coating: the coating prevents oxygen from getting to the top layer of Aluminum, so no hard oxide layer forms. If you can keep out all of the oxygen (you won't), then you are okay, but what really happens is oxygen gets in through very small holes. This oxygen starts crevice corrosion, which eats away under the coating.
    It is common to have trouble with rim leaks on older alloy wheels, especially if tires have been remounted a few times.
    Tom
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I have filiform corrosion starting on 2 wheels at the edge of the center holes. Later this summer I'll probably polish it out and re coat with clear.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Alloy wheel corrosion is a common problem here. Anyplace you have road salt in winter, the clear coated wheel can't keep it out. I solved the problem - sort of - by running winter tires on steel wheels in winter. The alloys stay in the heated condo storage unit.
  6. IleneG
    IleneG New Member
    Exton, PA
    Tom[/quote]
    Hello,
    We have a 2007 Prius. It was mentioned: "
    I have filiform corrosion starting on 2 wheels at the edge of the center holes. Later this summer I'll probably polish it out and re coat with clear". Could you tell me what the name of the "clear" product is?
    Thank you
    Read more:
    http://priuschat.com/threads/corroded-alloys.19350/#ixzz25Jf3szVd
    Tom[/quote]
