Cost for brake repair?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ddprius, Mar 1, 2022.
  1. Ddprius
    Ddprius New Member
    Michigan
    79F2C711-FC74-4BE3-8E6D-C1DD4276E306.jpeg Brakes on my prius felt funny yesterday, So I had it towed to the nearest dealer and they gave me this quote without any explanation. Wondering a couple of things. ( See attached picture)
    1. is this quote reasonable? I have no context for what these posts cost but it seems like they are charging an exorbitant amount for brake fluid so I’m worried the other prices may be inflated?
    2. If this is a reasonable quote, That does it make more sense to trade-in for a new used Prius? I put my car into Kelley Blue Book and it said anywhere from 3500 to 5500 in fair condition ( aka needing repairs) and I’m just wondering If it makes sense to pay $3000 in repairs in the car is only worth a little bit more than that
  2. artistic_gore
    artistic_gore New Member
    24
    Washington State
    They are charging a premium for the parts but not a huge amount, brake booster >
    2012 toyota Prius Brake Master Cylinder. Brakes, Leak, Repair - 4705047180 - Genuine toyota Part
    , master cylinder >
    2012 toyota Prius Brake Master Cylinder. Brakes, Leak, Repair - 4705047140 - Genuine toyota Part
    I can't speak to the labor piece, I know they have to remove the tray under the windshield to get to the area and they have to bleed the brakes using Techstream, as for how long it would take, I'm unsure.
  3. PriusCamper
    PriusCamper Senior Member
    11,091
    4,513
    Pacific Northwest, USA
    Most people can get this work done for near 1/3 the price... 8.5 hours labor seem a bit high... And a ten year old car doesn't require brand new $800 parts when the exact same used part is in the $100 range. Find a more affordable mechanic or find a friend to get on Prius Chat and DIY it.
  4. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    Those parts are expensive. You may be able to find them online for less.
    There are a few places online that "refurbish" them, but only give a 30-90 day warranty.
    It doesn't seem worth it, at least not to me.
    And getting a used part, well, how long will it last before you'll need to replace it, again????
    Unless you KNOW for certain that part was recently replaced, you're again risking having to replace
    them again. And the labor cost will be the same.
    Just because the car is older, doesn't mean it's not worth the cost of repairing it.
    If you spend the money for the new parts, it will probaly be 10 years before they need replacing again.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,952
    4,707
    Texas Hill Country
    I doubt you will get good value for a Prius with a $3,000 critical safety system flaw. If the miles are reasonable and it does not have excessive oil consumption, a bad hv battery or other significant damage, I would fix it before trading. I would also check the market for a viable replacement at a cost you can handle.
    Toyota was replacing the flawed design brake booster free under a customer support program. It is more limited program now, available if the car is less than ten years from date of first use and is under 150,000 miles. If you qualify, push Toyota for a free repair. It is not a given the dealer will check as they make far more if you pay.
    If necessary, an independent hybrid repair shop should have lower labor prices because most mechanics who have done it before can do it quicker. I have never seen a real reconditioned part for these items, one Florida guy claims the gen2 has such a supplier but no contact information has ever been provided. I believe there are no reconditioned parts because of the complexity of these brake by wire systems and the fact Toyota was doing it free for everyone until recently.
    Used parts are an option but there are many variations, even in the same year. Toyota has superseded some of the parts because of the poor design. So if used is dictated by finances, it is necessary to find part numbers using your vin and then use the donor car's vin to verify its brake booster. Most used sellers don't know this and go by housing numbers which are meaningless since they are the same across variations. You then have six to nine hours of non-refundable labor wasted if the wrong used part is installed. Or if it is also bad.
    There are online Toyota dealers like McGeorge that will source new parts with decent discounts. You email them with your vin to verify their online system has selected the correct brake booster assemblies.
    Finally, whoever changes the part must use an advanced scanner to calibrate and flush the system. Check with independent hybrid shops and other Toyota dealers for the best value with a guarantee.
    #5 rjparker, Mar 1, 2022
  6. Mendel Leisk
    38,702
    These doc's are related, give some idea of the complexity. There were conditions under which it would be done for free, but I think (due to miles/months) that ship has sailed for most owners
    Frustrating for sure, and more-and-more, Toyota is telegraphing the message that they don't stand by their products, even when there's an unacceptably high failure rate. Maybe more so...
    #6 Mendel Leisk, Mar 1, 2022
  7. rjparker
    7,952
    4,707
    Texas Hill Country
    It seems they are limiting most customer support programs to 150,000 miles which matches their best legacy hybrid system warranties in carb states. They did extend the 2020-up new car hv battery warranties to ten years 150,000 miles in all states. The gen3 inverter flaw still has 15 year unlimited. Lets face it, gen3 was a bad design.
  8. JSB_99
    JSB_99 Member
    66
    47
    Houston
    As mentioned looked for a hybrid shop in your area and see if they can do it. There is one here that will do it for $1900 out the door with brand new toyota parts. They also caution against using used or " refurbished" parts.
    Fred Haas Toyota here in Houston also had the parts for under $600 each last time I looked and they ship if you can find someone to do the install. I've considered doing the job myself but for $700 extra with it being done by someone who does these all the time and gives warranty i'm going that route.
