Cost of 100K maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GasSippr, Feb 13, 2014.
  1. GasSippr
    GasSippr Junior Member
    56
    Cincinnati
    galaxee said:
    another public service announcement from your friendly tech and translator :)
    just a list of commonly recommended services, whether they're needed and if so, when, and other useful info.
    1. brake flush
    may be a good idea after 100k miles/10 years. completely cleaning out the whole system is near impossible with standard brake flush equipment (mainly because the prius has almost 1 gal of brake fluid in it!) possible complications include air in brake system, damage to actuator or solenoid valves. (PS to those of you worried about rusting... the calipers are aluminum body construction with a composite plastic piston.)
    2. clean/adjust rear brakes
    only if you have drums (obviously in the prius, we do). ideally, for optimal brake life and performance, this is probably a good idea every 30k miles. for other cars, 15k a better idea. when you hear a tone out of the rear brakes, it's either time to change the brakes or have them cleaned/adjusted. if it's not done, you can see an increased brake wear rate (front and rear). possible complications are problems due to technician error- adjustment extremely tight can overheat a bearing. otherwise noise, brake chatter, or increased wear rate and glazing if not properly adjusted.
    3. transaxle fluid
    there is no way to "flush" the trans on a prius. if someone tries to sell you this, run. they can drain and fill, however. the fluid is expensive and is supposed to go 100k, but you can never go wrong changing it early. in most cases it isn't necessary. this is the same fluid that goes into a tundra for 100k under towing conditions. the only complication you might see is again due to tech error- using the wrong fluid or not filling all the way.
    4. engine and inverter fluid
    drain/fill is OK, but NO flushes. it's not even possible on the inverter and the engine is difficult but not impossible, however NOT recommended as it can cause serious damage to the electric water pump and switching valves. you do not need the drain/fill until your car hits 100k. if the coolant is still nice and pink, don't do it then either. again, the coolant is said to go 100k. while you're not going to do any wrong by changing it early, again it is expensive like the trans fluid. possible complications include more tech error- bleeding these systems is a PITA and getting all the air out is hard. an incomplete fill, use of the wrong coolant, can damage your car.
    5. EFI or fuel injector cleaning
    really not necessary until you see 100k, if you have a bad tank of gas, or if you start seeing misfires (and you'll see a check engine light when that happens.) possible problems include damage to fuel lines or connectors while disconnecting/reconnecting the adapter equipment to the system. the fuel line that you would access to hook up the adapter is directly above the exhaust manifold... NOT a place you want a leak. other possible problems could include seal failures due to pressure (rare but possible.) since it doesn't idle, most techs will get in and stomp on the gas pedal until the EFI cleaner runs its course. this leads to a condition called "blinky check engine light" which means that you have overheated your catalyst and are in serious danger of melting the insides of your catalytic converter.
    6. three-part service, fuel induction service, throttle plate cleaning
    these are all different names for essentially the same service. (the "three part" also includes a top engine cleaner aka fuel induction service and fuel additive.) this is really only needed if the throttle plate starts to stick. a good idea after 100k, but just the throttle plate cleaning. there is no accessible port to feed the top engine cleaner through, and fuel system additives are not recommended with the bladder fuel tank. possible complications from doing various parts of the service: fuel tank additive can possibly damage the fuel system- unlikely but still possible. biggest issue with this is deposits on the spark plugs, causing reduced power and fuel economy. for the throttle plate cleaning, using too much of the cleaner can cause the car to run funny for a few minutes but that's about it.
    7. PCV valve replacement
    a good idea at a 60k interval just to be on the safe side. if this fails, it will either stick closed (rare) and blow oil seals, or stick open and allow oil to enter the intake. most people forget this valve because it's hidden. but it's a simple replacement and damn hard to screw up.
    8. alignment
    depends on your driving style. aggressive drivers should have it checked every 10k. otherwise every 15-20k just to make sure it's right. a MUST when replacing tires and if you notice uneven tire wear.
    *if you have a question about something that's not listed here, please do ask.​
    So I have two questions:
    1) My Toyota dealer quoted me $390 for all of the above except #5, #7, and #8. Is this a good deal? If not, could a "regular" mechanic do this (someone who doesn't do much work on hybrid cars). Spark plugs would be an additional $100.
    2) Toyota dealer said they didn't do #5 or #7 typically unless their was a "problem." Should I have them or other mechanic do it anyway?
    They said the job would take 5 hours and I could use a loaner car for free I lik
    Thanks!
    Read more: http://priuschat.com/threads/what-services-you-need-and-what-you-dont.28970/page-37#ixzz2tE01P5YJ
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
    tangerino likes this.
  2. Rich12
    Rich12 Member
    176
    29
    All of the above is DIY, esp. plugs, PVC, and transaxle drain-refill. You could do an alignment yourself, as well. I wouldn't mess w/ the coolant or brake fluid myself, though.
  3. GasSippr
    56
    Cincinnati
    Thanks for the reply. I'm actually not quite handy - I botched a spark plug change on my old '96 honda van (broke the plugs pulling them out) and then needed my mechanic to rethread the holes where the plugs go. However, I have done the 12v battery change on the Prius with not TOO much hassle though it did take several hours. I'm afraid to mess up anything on my "baby" :)
  4. GasSippr
    56
    Cincinnati
    Thanks for the reply. I'm actually not quite handy - I botched a spark plug change on my old '96 honda van (broke the plugs pulling them out) and then needed my mechanic to rethread the holes where the plugs go. However, I have done the 12v battery change on the Prius with not TOO much hassle though it did take several hours. I'm afraid to mess up anything on my "baby" :) Also don't have a garage or any tools.
  5. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    Where are you located? I think that is very good price. I also need to do 120K service and have called 10+ dealers in Atlanta and these are the cheapest price I could find. I am planning to do the services next week.
    Spark plug replacement: 87.88
    PCV valve replacement: 20
    Transmission fluid drain and fill: 79.95
    Coolant drain and fill for engine and inverter: 66.10 each
    Brake fluid flush: 70
    Drive belt replacement: 121
    Alignment: 69.99
    Water pump replacement: 306
    Water pump+Drive belt: 418
    Water pump+Drive belt+Engine coolant replacement: 452.
  6. Patrick Wong
    18,200
    6,479
    All of those prices look good except the engine coolant pump and serpentine drive belt replacements.
  7. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    Thank you. I was told I have a small leak, so I'm not planning to replace the water pump immediately. But what would be reasonable price for water pump and serpentine belt replacement?
    iPad ?
  8. r619
    r619 Junior Member
    38
    Atlanta, Georgia
    iPad ?
  9. Patrick Wong
    18,200
    6,479
    IMO a price of $350 for the engine coolant pump, serpentine belt, and engine coolant drain/replace would be fair.
    I recommend that you keep an eye on the engine coolant level, both in the reservoir and in the radiator itself (need to remove the large black plastic cover to gain access to the radiator cap.) If the pump develops a substantial leak, air will get into the system and the reservoir will not be able to replenish the radiator. The level should be kept at the full mark on the reservoir and at the top of the radiator neck, when the engine is cold. Use pink Toyota Super Long Life Coolant.
