Cost of an Oil Change when you bring your own oil and filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GasSippr, Feb 6, 2012.
  1. GasSippr
    GasSippr Junior Member
    56
    Cincinnati
    So I've read a lot of stories about overfilling of oil when someone else does the oil change. My question is if I bring my own oil (3-3.5 quarts) and filter to my mechanic what would be reasonable price for them to charge?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    $20. But ask him how much more to check the trans fluid level while he's there. If he's a professional mechanic it will be up on a lift which is then a breeze to check. You just unbolt a big bolt up on the top side of the cv case. Stick your finger in the hole and should be fluid right to the top the top of the hole. Ask him how it looks on a paper towel. Then while your rapping give him a $10 tip upfront and ask him to to check under the front for any issues...leaks...condition of cv boots.
    He'll remember the tip next time.
    But if you have more than 50,000 miles on the car the trans fluid needs to be changed anyway.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,323
    CA
    I have paid as little as $10 at a Nissan dealer. Personally I think $25 is reasonable.
    There's no reason to check the fluid level if there is not a leak. Anytime you open the fill plug you will also need a new $2 washer.
  4. edthefox5
    10,096
    4,812
    Clearwater, Florida
    There's every reason in the world to check the OP's trans fluid.
    Its probably never been checked.
    It could have been low from the factory. Mine at 5K miles (first change) )was so low below the hole I could not get my pinky wet.
    Who knows how many miles on the car and how it was driven. The fluid might be toast and a competent mechanic can tell that at a glance.
    In fact its probably way overdue for a change.
    And on and on.
    Not to even check the trans fluid on a 5 year old car (especially this car)
    is ridiculous.
    And you don't need a washer every time you take the plug out. Mine's been out twice and its fine. Same with the original washer on the oil pan bolt.
  5. hschuck
    hschuck Member
    385
    17
    bay city, ca
    I've had my oil changed every 5000 miles at my Toyota dealer since it was new. (2005 W/100k miles.) I provide my own oil (mobil1), dealer provide filter, etc. performs inspection and car wash. Cost is $18 to $20.
  6. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    Kahlo Chrysler N of Indy has a ongoing special of ONLY $60 + tax for a package of 4 oil changes...with filters, oil, and totally visual checking your fluid levels, brakes, tires, etc. The 4 have a 1 year period and they do not demand you get it fixed there. They offer this for any car that has your normal capacity and uses dino oil. If you bring in your own oil and filter they still do all the work mentioned and charge $12 only! I used to have a sponsor on my race/street cars that did all my changes for free...even synthetics, but he's gone now.
  7. wjtracy
    wjtracy Senior Member
    11,335
    3,596
    Northern VA (NoVA)
    ...I used to supply the oil quite a bit (becuase I could not get the darn lug off) and its $15-20 or free Toyota shop was free for the first 3 fills. I'll say 3.0 quarts is all I ever need. Give them 3 and fill up slightly more at home if needed. I aways save some empty Mobil-1 quarts in case I want to give them 3 qts out of a 5 qt bottle.
    >>Price checked at Walmart tonite Mobil-1 five(5) Quarts $26.48 !!! except some viscosities were a few more bucks. Also it is Mobil-1 5qt bottle especially made for Walmart, and the idea is you put your used oil back in the bottle and take it back to Walmart. That is quite nice cradle-to-grave idea!
    However, did you ever notice the landfill (stack) of used 12v batteries in the front of some Walmarts (like mine)? Does not look too safe.
