Cost of Brake Replacement (Pads, Rotors, Calipers) for Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HAC, Sep 17, 2013.
  1. HAC
    HAC New Member
    Hello,
    I have had my 2010 Prius since January 2013 when I purchased it used from a family member. It had 63,226 km on it at the time of purchase. I am now at 74,500 km and took my Prius in for a routine service appt at a dealership and to fix the brake booster pump recall.
    I was told that my front brakes are at 30% and my rear brakes are at 5%, and that my front and rear rotors, front and rear pads, and rear driver side caliper all needed to be replaced.
    I was quoted the following from the dealership:
    $198.00 - Front Pads
    $320.00 - Front Rotors
    $198.00 - Rear Pads
    $320.00 - Rear Rotors
    $739.00 - Rear Driver Side Caliper
    This seemed very expensive. I am hoping to find a local garage to do this at a reduced price, and am looking for any others who have also had to replace these parts - what was the ballpark cost for your repair?
    In addition, had any other users had to replace the brakes by as early as 74,500? I have read some reviews and it seems awfully early to require these parts.
    Thanks a lot in advance.
  2. Mendel Leisk
    41,176
    Try a second dealership if you can.
    If all those parts are in fact needed, it would seem to indicate a long period of neglect, small problems becoming big...
    It's a little suprising, to be needing new rotors all around, and a new caliper. Again, see if you can get a second dealership to look at it. If they recommend similar course of action, at least you know.
    I had a recent conversation via email with our nearby dealership's service manager. Here's his opinion on Prius/Brakes:
    Prius brake service recommendation - from a Toyota service manager | PriusChat
  3. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I just got my quote from the Toronto dealer. Looks like they are close to what you got.
    A) Replace front and rear brake pads with shims. $425
    B) Replace rear brake rotors. $297
    C) Machine front rotors. $185
    Your profile does not indicate your location so you can use the above as your reference if you are in Canada.
  4. Den49
    Den49 Member
    498
    272
    Maryland
    The brake parts you list above can be purchased from Advance Auto and Rock Auto in the U.S. for about $375.00 plus tax and shipping. There are independent shops here that replace Prius brakes. My guestimate is that you could get that job (parts and labor) done here for $750 to $800. It is questionable whether all the above parts need to be replaced.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It seems ridiculous that these parts need replacing @ that mileage/er distance. Where do you live? As mendel suggested, get a second opinion.
  6. bisco
    51,764
    any competent mechanic can do this work. i agree on a second an even a third opinion. there are a few reports of early brake work, but it is unusual. all the best!(y)
  7. The Critic
    The Critic Resident Critic
    3,193
    2,332
    CA
    There are a couple threads on this forum regarding the rear pads seizing up in the brackets, and causing them to wear out prematurely (and irregularly). I suspect that this is the reason why your rear brakes are needing to be replaced so soon. The salty roads in Canada are a major contributor to this issue.
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    As suggested above get a couple of other estimates, what you have been quoted may be too high. I agree with Spiderman your mileage is pretty low for all those parts to need replacement. Most Prius owners seem to be getting well over 100K on brakes with no problems, of course most of us, thankfully, don't live where they use salt on the roads.
  9. Den49
    Den49 Member
    498
    272
    Maryland
    ^Most G3 Prius owners have not yet reached the 100,000 mile mark so it is too early to say "Most [G3] Prius owners seem to be getting well over 100K on brakes with no problems". Also the G2 Prius, which typically does go more than 100K with no brake problems, has rear drum brakes. The G3 has rear disk brakes for which we are beginning to see incidents of premature wear and failure. More time and miles are needed on the G3 population to draw definitive conclusions.
  10. Walk_the_walk
    Walk_the_walk Junior Member
    23
    Central Florida
    We just got back from the dealership (which is a posting unto itself - stay tuned) and our 2007 Prius with 92, 445 miles on it, we still dont need new brakes... or rotors... I agree. Sounds suspicious.
    retired4999 likes this.
  11. zander
    zander Junior Member
    46
    connecticut
    Don't buy these parts from Advanced Auto or Auto Zone. Buy OEM parts and due the work your self
  12. gliderman
    gliderman Active Member
    751
    225
    Who has the best price on OEM brake parts?
  13. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    Google "OEM Toyota parts" or "Genuine Toyota Parts"and start down through the list. My dealer quoted me $252 for a Gen III key fob. I found it at a an online Toyota dealer for much cheaper.
    An interesting side note is the online dealer is only 50 miles away, so I called them and they said this price was only good for online purchases. I was able to purchase it online and then drive down there and pick it up.
    Also, dealers have the highest overhead of any automotive repair business. Therefore, their labor rates are also the highest. I would shop around for the best labor rate in your area.
  14. tumbleweed
    4,067
    691
    Eastern Oregon
    My goodness how embarrassing, I thought people would realize that I wasn't referring to those of us who have not reached 100K miles yet. :)
  15. Den49
    Den49 Member
    498
    272
    Maryland
    Not meant to embarrass, just a warning to G3 owners that it is early in the life of the G3 cars; and, it is becoming increasingly apparent that the G3 rear disk brakes will not tolerate service neglect as well as the G2 drum brakes. The good news is that the G3 rear disk brakes stop better and should last a long time, as long as the brake hardware is cleaned and lubricated every 30,000 miles or so, according to what I observed when I serviced mine.
  16. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Apparently G3 brakes are a lot less wear proof than G2. My front pads had worn out at 60,000 miles, and I use regen braking almost exclusively.... no better then any other non hybrid to my mind.....
  17. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    That price seems very high.
  18. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Without knowing where the OP is, you can't guess how much a $ is worth.
  19. alaskaraven
    alaskaraven New Member
    I just took my 2010 prius in for the brake accumulator recall. I noticed a squeek when I went to pick it up and the service person said it was probably a rock in the brake. they took the car back in and told me that my driver side rear brake callipers and rotor were in need of replacemnt. I thought it was odd that only one side was bad. of course they need to do the work on both sides. My driver side rotor was rusted and it was gouged. In my research I have found that if the brake accumultor fractures, it will leak nitrogen gas in to your brake fluid causing RUST. I do not think i should have to pay for this. My car has 53000 miles.
  20. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I'm at 200,000 kms (124,000 miles) and brakes are about 60% worn. No rear brake problems.
