cost of bumper cover
Discussion in 'Gen 2 Prius Main Forum' started by harper42, Aug 22, 2007.
  1. harper42
    harper42 Member
    226
    Several months ago, I was following a semi type truck that ran over a mass of metal debris. My Prius was next. Insurance did cover it. Yesterday a guy in a jeep, with a trailer jack, backed into me in WalMart parking lot; then off he went. I hate to turn this into insurance and appear to be a bad risk. How much would a Prius 2006 front bumper cost? Could my local body shop do it; or need it be done by Prius dealer?
  2. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(dulcimer @ Aug 22 2007, 01:40 PM) [snapback]500571[/snapback]</div>
    Any "GOOD" body shop can do a good job relacing the bumper cover for around $550 to $600. Toyota body shops don't have any big secrets.
    Bumper covers are very easy to take off and reinstall. The problem is getting the replacement one painted. If you can get someone to paint it for you, you might save about $100 labor, but many shops will not want to guarentee their paint if they don't install it, and they may charge you a $100 install it yourself fee.
    The other option would be if you could find one the same color and good condition in a wrecking yard, it would probably be around $250.
    If you are good with paint, and by good quality catilized primer, color coat and clear coat from www.paintwould.com for about $80, you can get a halfway decent paint job if you keep your coats wet enough to not get any tiger stiping. I did this sucessfully on a bumper cover, but did not get acceptable results using duplicolor sold at discount auto stores. www.paintworld.com has truely superior rattle can paint.
    So, to make a long story short, you may just want to pay the $550 or so to get it done and guarenteed.
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    Should be covered under comprehensive if you decide to file a claim.
    I think the cost of the bumper cover itself is a couple of hundred, but the cost to repaint it is much more; the cost to repair and repaint my rear bumper cover was $700 including the cost to replace my rear bumper protective decal.
    Your local body shop could do the work; you do not have to use a Toyota dealer.
  4. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
  5. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    i bought mine on ebay, used i got it for 60 bucks needed to be painted though, which i did.
  6. ohioflash
    ohioflash New Member
