Cost of electricity in CA for Prius plug in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Nett44, Sep 8, 2012.
  1. Nett44
    Nett44 New Member
    Hey everyone in California....
    I want to buy a Prius Plug in today but I am worried and wondering how much will it cost me in electricity a day to plug in at home. We have PG&E and we go from tier 1-3 depending on the day.
    Thanks,
    Nett
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    How much does 1 kWh cost you depending on time of day? A full charge takes 3.4 kWh.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  4. dulenomochafahe
    dulenomochafahe Junior Member
    Jump from tier 2 to tier 3 on my last 5 statement days after I purchased PIP. You will expect $15-$20 more.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    a day? or per month?
  6. hill
    8,163
    That all turns on how frequently per day you charge at home.
  7. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    Are you on the E1 rate plan?
  8. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    On my rate plan, which I switched to being more PHEV car friendly, it's 19 cents an hour to charge and it's a 3-hr charge. About $18 a month if I charge nightly, every night.
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    OP needs to answer many questions, such as their rate schedule and what tiers they're in now. If they're on a TOU plan, what tiers are in they in, when they charge?
  10. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    PG&E's regular rate for residential service is E-1 and uses tiered rates which increase due to increased energy consumption to encourage conservation but which are the same regardless of the time of day. For electric vehicle owners they also allow switching to an "experimental" E-9 rate that is tiered but charges different rates depending on the time of day and winter vs. summer. This E-9 rate is now being phased out in favor of a new "EV" rate which is not tiered by usage but is charged by time of use. Overnight off-peak charging will be $0.097 per kWh.
    You can find a recent slide presentation given by PG&E to a Nissan LEAF owners group (SF BayLEAFs) about the old and new rates at Free Cloud Storage - MediaFire.
    The new rates will become available in a few months at which point the older E-9 rates will no longer be available to new users but will be retained for about 2 years for existing users during a transition period.
  11. tpilkington
    tpilkington Junior Member
    I am on a plan that has lower rates at nite...a charge costs me about $0.16...I program the car to turn on at midnight...
  12. hill
    8,163
    I Duno ... Call me wackey ... if I wanted to buy a Prius "today" ... I'd have already done the math as to what my utility charges me for electricity ... weather the charge is for nighttime - daytime - holiday - weekend - summer - winter - heavy use - light use etc. Isn't buying a Prius 'today' ... & then inquiring about electricity costs putting the horse before the cart?? I'd at least do a little bit of my own " electricity costs" homework before I ask somebody else. because who knows anyway - if all/any of us PC'rs know what the heck were talking about. Like I said .... call me wackey.
    SGH-I717R ? 2
    Epiphany2000 and cwerdna like this.
  13. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    I think that sometimes, even WITH all the numbers, it's still a little difficult because of the variability of programs for EV/PHEV from California electricity providers. For me, I could go with TOU, but I'd end up spending MORE because of the way it's set up. I could spend some money for a sub-meter and then I'd SAVE money, but not really until I'd paid for the sub-meter and its installation. Regardless, even if you do a diligent job of finding out what will happen to your energy use profile with a Pip in the driveway, there are still lots of other variables to work through.
    In So Cal, it's not hard to land in Tier 3 land with central air and a few other goodies - at least from August through October. So that's yet another variable to consider.
  14. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep, there are several electricity providers in California (e.g. PG&E, SCE, etc.).
  15. David Welch
    David Welch Junior Member
    How are you getting the 3.4 kw total? Book says 12A @ 3 hours = approx 4.5 kw to charge.
    SAMSUNG-SGH-I727 ? 2
  16. hill
    8,163
    That maybe accounts for loss pushing power into the pack as well as loss experienced charging at 120 volts - which is worse than loss @ 240v.
    A500 ? 2
  17. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Several members here have measured the current used to fully charge a depleted battery, using instruments such as Kill-A-Watt.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    last nite I charged my battery that was fully depleted (ICE came on when I pulled into my parking spot to charge) Kill A Watt reading: 2.86KWH
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    on 9-6-2012 EV remaining before charge: .1 mile, full charge Kill A Watt reading: 3.06KWH
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    AND........if you're a ChargePoint customer you can get KWH readings from their website when you plug your car in at their stations. which use either 240 volts or 120 volts to charge up.
