Cost of using EBH
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Kremtok, May 17, 2008.
  1. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Greetings folks,
    Recently I've installed an Engine Block Heater in my 2008 Prius, and I've seen considerable gains in fuel economy since the installation. However, I have a problem. My family and I live in a condominium with a common garage, and my neighbors can't wrap their brains around the concept of using an EBH in a 60-degree heated garage. They're concerned that it's costing them unbelievable amounts of money, since the electrical outlets aren't individually metered.
    Here's where I need some help. I've done some calculations on the cost of using an EBH on the Prius. Can someone more knowledgeable than me review my work for accuracy, please?
    KILOWATT (kW) = VOLTS x AMPERES x POWER FACTOR / 1000
    kW = 120 x 2.5 x .85 / 1000
    kW = .255
    .255 kW x 24 hours = 6.12 kWH
    6.12 kWH x $0.09476 = $0.5799312
    Overall cost would be about $0.58 per day, well short of the $3.00 per day they're assuming it costs them, even if I were to keep the car plugged in for the full 24 hours.
    Thanks to all who are willing to assist with reviewing my math - if there are any obvious errors, please accept my excuse that I know nearly nothing about electricity and all that I do know was learned on Wikipedia in the last 10 minutes.
    EDIT:
    Corrected formula for determining cost is as follows
    Power in Watts x Hours / 1 000 = kWh x Cost per kWh = Total Cost
    400 Watts x 24 Hours / 1 000 = 9.6 kWh x $0.09476 = $0.909696
    Actual cost for 24 hours of EBH use at my current electricity rate is about $0.91.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    I can't comment on your calculations, you probably know more than I. But I'd suggest you use a Kill A Watt meter so you can show your skeptic neighbors exactly how much electricity your EBH uses. It's also handy identifying other energy suckers.
  3. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    Your math is correct, assuming your 120 volt block heater eats 2.5 amps (ie. 300 watts) and you have it plugged in 24 hours a day.
    I'll second the idea of a KillaWatt meter to show them you are not pulling much. I'll agree it's strange to see a block heater in a heated garage, even in Alaska.
    Perhaps they're afraid you'll get the "gas" for your car from the electric plug. MAny people may still think Hybrids need to be plugged in.The average person probably doesn't know about the PHEV plug-in conversions, but the reality is, you COULD be getting your "gas" from the plug. How would they know, other than suspiciously higher bills ?
  4. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    The EBH is reported to draw about 400W, though the Kill-a-Watt will pin it down.
    If it won't grow legs in the community garage, I suggest adding a timer to turn the heater on about 3 hours before your scheduled departure. The heater seems to reach a point of diminishing returns beyond that, and additional preheat time probably is not cost-effective. That might serve the added benefit of appeasing the neighbors.
    As for whether it is worthwhile in a 60-degree garage, I vote "yes." Starting off with a block at up to 140F instead of 60F makes a significant difference in fuel economy for the first 5-10 minutes of driving.
  5. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Hi Kremtok,
    First congrats for installing an EBH. I also park in a condo underground garage and wonder about your circumstances as to where were you were able to plug in. My condo is a high rise with lots of units each with their own parking space. There are no plugs inside the parking garage except a GIF plug in the car wash bay.
    If I could plug in somewhere I would definitely have the EBH installed. Good on you, hope you can quiet down the neighbours. :)
  6. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I'll bet you won't get your neighbors to believe you despite any arguments or calculations to the contrary. Some people are like that.
    ZC1
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I DO have a "Killawatt" meter and the block heater is a 400W one. So if you left it plugged in 24 hours a day it would consume .4 X 24 kWhrs or 9.6 kWhrs per day. At your posted costs, that's $0.09476 X 9.6 = $0.91 per day. As you obviously drive some of the time, it's less than that. I'd offer the condo. association $150 per year for the privilege of 24 hour a day block heater use, just to maintain peace in the neighborhood. ;)
    BTW, the power factor to use is "1". It's a resistor, not a reactive load.
  8. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Thanks to all who provided such helpful responses! Mr Beale, your suggestion is very helpful, and that's probably what I'll do.
    Of course, they're going to want to continue arguing about it without actually coming to any type of conclusion or agreeing on a solution. My main argument is that we share the cost of heat and hot water in the building based on square footage of each unit. That sounds like a good idea, but the number of people in each unit has a greater effect on hot water usage than square footage, and the set point for your thermostat has a greater effect on heat usage than square footage, as well. Therefore, my family of 3 uses less hot water than most others in the building, and our thermostat set at 65 degrees uses far less heat than the others who set theirs between 68 and 72. Because of this, I think my neighbors should eat the $0.91 per day that Mr Beale came up with, lest I start complaining about heating my neighbors' homes and paying for the hot water in their children's baths.
    Wow, that's quite a rant! Sorry about that, but thanks again for all of your help, folks!
  9. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    Does the EBH turn on and off to hold it at 140F? If it does being in a garage would reduce the cost.
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    The EBH is just a big dumb resistor. As long as its plugged in and has power it will create heat. Best thing to do is put it on a timer.
  11. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    You're right - a timer is the best option. I just went to Wal-Mart and picked one up.
    Unfortunately, when I went down to my car, it had been unplugged. Something tells me this is going to be one heck of a fight.
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    While others have corrected the wattage and power factor, I'll
    correct the usage. You don't need to leave it plugged in 24x7, you just
    need a 2-3 hour shot before leaving. There are diminishing
    returns from leaving it plugged in any longer than that.
    _H*
  13. Nords
    Nords Member
    101
    Oahu
    And I wonder if that would be better accomplished through a battery pack or even an UPS instead of though 120v AC.
    Kremtok or others, can you be more specific about the MPG gains? I'd like to price out the savings at the pump vs the electricity cost. While Oahu gas prices are pushing $3.75/gal, we're also paying 20.5 cents/KWHr and our photovoltaic array isn't entirely covering our energy demands.
    In general, after decades of experience across the nation, I've come to the conclusion that condo associations suck. You'll probably succeed in finding a way to power your EBH without their support before you can change their behavior to support you... or you'll find rocks in your tailpipe too...
  14. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    Here's an update that will make you laugh! I called my property management office about my neighbors harassing my family and tampering with my car. They told me two things:
    1. I'm foolish for plugging in my car in a heated garage (actual words)
    2. Considering the low cost of an EBH on a timer, they don't see my neighbors' complaints as being valid
    So like I said before - it looks like we'll continue to argue, but no conclusions will be reached and no solutions identified. Oh my this is fun!
  15. zcat3
    zcat3 New Member
    117
    35
    SF Bay Area
    Let your neighbors know that since they are paying to heat the garage, they will be paying a bit less as your 140 degree engine block will act as a heater as well. Actually, depending on how the garage is heated, the EBH may cost nothing additional to the building.
  16. yams69
    yams69 Junior Member
    Bucks County, PA
    Kremtok...human race.
    Human race...Kremtok.
    Look on the bright side...with those neighbors, if it weren't the EBH, it would probably be something else.
    Wonder what they'll do when you start charging your electric car in that garage?:D
  17. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    I've seen Eliminator PowerBox units Canadian Tire advertised and been thinking if they could be used as portable power for EBH? After Nords posted the above comment I did some further research. I'm technically challenged and hope that you'll comment on the viability of this as a solution for these condo situation or perhaps when people are away from home (like work). I found the manual for this unit on-line - see attached. The unit "has 3 household outlets to power up to 600W of appliances and electronics simultaneously". More importantly (I gather) it states in the manual that the "maximum sustained load is 480W". Since the EBH requires 400W I believe this unit could power the EBH. I would connect it to a timer and use it at home and at work for 3 hours each per day. Recharge it at night inside my unit and/or at work (have to see how long does it take). What does everyone think about this alternative?
    Kremtok,
    If this works forget the condo board and "unreasonable" tenants just buy this unit and charge it once a day inside your unit then charge the EBH. For a little more than the $150/yr it was suggested to pay the condo you can buy this unit (on sale this week at $180). The other part I'm not sure of it is logistics - where to put this (inside the cabin or trunk?) and how to run the wire to the EBH? Any ideas? Living it outside the car maybe risky.
    Thanks in advance for everyone's comments.:)
    Gabe
  18. JimboK
    2,817
    187
    49
    Chesterfield, VA
    My first reaction is that with only 28 Ah @ 12 V, this wouldn't work. But I'm technically challenged too. :confused:;)
    When I moved into my new townhouse last fall with nowhere to plug in, I wondered aloud in CleanMPG whether a battery/inverter combo would be feasible. This was my thought process, pasted from that post:
    "Some simple math suggests I would need an absolute minimum of 100 amp-hours, assuming a 12V battery: 400(W) ÷ 12(V) * 3(hours). That then gives a complete discharge, and with daily cycles I suspect even a deep cycle battery wouldn't last a year. With 100AH, I'm sure it would take a pretty big -- and heavy -- battery, not to mention the added weight of one with greater capacity. Even so, I'm guessing it would have to be charged daily. You folks correct me if my (mostly uneducated) assumptions are wrong, but it seems that the cost of battery(s) and inverter, conversion losses partially limiting the energy consumption advantage, and the hassle of lugging the battery back and forth would make this expensive and impractical."
    While no one explicitly verified my analysis, no one disputed it either, so I let the idea die. Having said that, I reiterate that my assumptions are mostly uneducated and I stand to be corrected.
  19. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    If I were you, I would no longer try to plug in your Prius. Most people can be an ignorant and violent lot, depending on circumstance.
    It's not worth any possible retaliation - damage to your car and especially threats against your family - to save a couple of bucks
    Put the extension cord away, and forget about it. Or you may need to rig up a security camera for your car and your suite.
  20. Fibb222
    Fibb222 New Member
    1,499
    99
    I say fight on and keep us posted.
