Cost to repair after collision?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by phillipreese, May 19, 2013.
  1. phillipreese
    phillipreese New Member
    Sacramento, California
    I
    Hoping I didn't total it ... 85000 miles ... 2008 ... Live in California ... No other damage except what you see it the attached file, except the radiator will likely need to be replaced ...
  2. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    You might try the other forum for more replies (this is the wagon area). But for what it's worth when I ran a body shop years ago assuming the airbag didn't go off I'd say no not totaled at a cosmetic level. My very very rough guesstimate is about $3k with no airbag involvement and a few decade old info that stays strangely not too far off. If damage to either mechanical or suspension higher.
    Hope it works out for you!
    Good luck!
    W
  3. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Moved to the Gen II forums
