Costco Velox rims
Discussion in 'Prime Accessories and Modifications' started by Rashid K, Mar 7, 2018.
  1. Rashid K
    Rashid K Junior Member
    Has anyone looked into Velox rims that are sold by Costco? They are currently $150 off a set of 4... the are about $90-120 each so getting $150 off a set of 4 is not a bad deal... just don’t know how heavy they are...
    Costco is doing $70 off a set of 4 Bridgestone and if you get both tires and rims together you get an additional $100 off..
    That’s $320 off a set of 4 tires and rims
    I wish the stock prime rims were black like the good old days, all I would do is remove the hub caps and be done.... I guess I could spray them with Plasti Dip, but that’s a hassle
  2. Mendel Leisk
    38,726
    My good ol' days are probably a bit older: stamped steel, silver finish, with a chromed hub cap in the center.
  3. farmecologist
    farmecologist Senior Member
    1,948
    1,786
    Southern MN
    Interesting. That does look like a good deal!
  4. SaraBBrown94
    SaraBBrown94 Active Member
    234
    262
    Pittsburgh PA
    I would go for the dipped ones if you just want black rims, 2 cans of black plastidip and 1 can of clear coat will do it for you. Around 15-20$ for less commitment.
    I can see the desire for a double set of wheels and tires for seasons though.
  5. PvPDX
    PvPDX Junior Member
    58
    Portland Oregon
    2015 Prius v wagon
    I just ordered a set of black Velox Nirvana wheels for my v. 17x7 were 19.5 lbs. Costco did not have that model so I ordered from Americas Tire. Only $129 each. Call Velox customer service if you have any questions, they were very helpful.
    #5 PvPDX, Mar 7, 2018
  6. Rashid K
    Wow those look great! I’ve used pastidip on my volt rims and when I changed the tires the coating peels off. Did you plastidip those hubcaps? I was thinking just spraying them with black spray paint....
  7. Rashid K
    Those are nice ones.... I really don’t want to go with 17s (don’t know how the smooth the ride will be afterwards) so I was thinking of going to 16s instead (might not even be worth the money to only go just 1inch bigger)
    PvPDX likes this.
  8. padroo
    padroo Senior Member
    2,763
    2,250
    I didn't add up what it costs for 15 inch tires, wheels and TPMS sensors but it was about $1,000.
  9. PvPDX
    PvPDX Junior Member
    58
    Portland Oregon
    2015 Prius v wagon
    I have the oem 17s and the ride is fine with the stock 50 series tires. 16s would be even cushier and if you have those now it would be much cheaper to just change the wheels.
  10. SaraBBrown94
    234
    262
    Pittsburgh PA
    Yeah they are plasti dipped black with the gloss top layer also being a Plasti Dip. No commitment there. It's a great way to try out different looks without investing too much or committing to anything.
    They don't look too glossy here since the whole car is covered in dirty winter road garbage lol 1520560329428.jpg
    farmecologist likes this.
  11. Rashid K
    That’s really nice! I priced out the 16in Velox rims and tires I want to be about $650, so it’s not that bad, and I think will help the ride handling a little.... too bad the rims under the caps aren’t just black like they used to be...
    Is your roof wrapped? Looks nice
  12. SaraBBrown94
    234
    262
    Pittsburgh PA
    YUP! It's pretty subtle looking, I think. This is my thread on it.
    Black Roof Vinyl Wrap | PriusChat
  13. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Ooh you sprayed the hubcaps? Nice! I just powered coated my wheels (y) check out my post :D
  14. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Did you remove the badge in the front? :eek:
  15. Rashid K
    I will never use plasti dip on rims again, it turns nasty after a few years and touch up is not they easy....
    Where did you powder coat them? How much??
    Thanks
  16. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    I will never use plasti dip either! Here’s a link to my post:
    Power Coated Wheels Glassy Black | PriusChat
    It costed me $300 for everything. Even the lug nuts.
  17. Mendel Leisk
    38,726
    I know I'll get boo'd out of here, but why-oh-why do you all want to look like you're on black steelies? Rims should be silver, it's the natural order, lol.
    Merkey and xliderider like this.
  18. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    BOOOOO! Get out of here! Just kidding but all jokes aside I like the two tone black and white since the car has a lot of black... and then having silver on it makes it out of place.
  19. Mendel Leisk
    38,726
    It's a generational thing, I'll get out of here.
    Merkey likes this.
  20. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Come back!
