Costco warns about replacing OEM tires
Discussion in 'Gen 2 Prius Main Forum' started by Ian MacDonald, Aug 24, 2008.
  1. Ian MacDonald
    Ian MacDonald Junior Member
    51
    Benica, CA
    I took my Prius into Costco on Saturday to take advantage of their latest $60 discount on Michelin tires. My OEM Goodyear Integrities were pretty worn out after 42K miles and I wanted to replace them with the Michelin X Radial DT. I had to leave the car with them for a while since they were really busy this weekend due to the $60 discount coming to a end on Sunday.
    I got a call about an hour later from them where they wanted to let me know that "Costco has learned that some folks are experiencing a reduction in fuel economy after replacing the OEM tires on a Prius". They said that they didn't yet understand why this was happening and wanted to know if I still wanted to have my (worn out) tires replaced. I told the installer that I did my due diligence and was aware that some folks see a small reduction in fuel economy before the new tires break in and that I was comfortable it would be fine to continue with the tire replacement.
    I'm curious if anyone else has had a similar experience with Costco or another tire dealer recently.
    Cheers,
    -- Ian
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    So their other option was to leave the old tires on until you get a blowout? :confused:
  3. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    17
    Actually, that just goes to show how conscientious Costco is with their members . . . not just treating you like a number by selling you a product and kicking you out the door.
    Costco has very liberal return policies. :)
  4. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I agree. This is good to hear. Kudos to Costco!
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Their other option would be to use Goodyear Integrity tires.
    Tom
  6. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
    And just let them know that any new tire will drop your MPGs for the first few K miles.
  7. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The GY Integrity tires available as replacements are not the same as the ones that came with your Prius (Made in US vs Made in Japan). I have seen reports of lower MPG with those as well.
    There are true LRR tires available that match MPG with the GYs in the summer and get better MPG, but still less, in the winter. My favorite at this time is the Nokian WR or WRg2 (some of their summer tires are LRR as well).
    JeffD
    ETP likes this.
  8. ThePackage
    ThePackage New Member
    74
    Frankly, I think it is irresponsible for any tire retailer, or anyone else, to plant a negative "seed" without explaining & showing plausible evidence to substaniate the reasons for their opinion. Oversize tires can increase the rolling resistance which could result in slightly lower gas mileage. My guess is that low or high tire pressure has a more significant effect.
  9. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    I would have considered Costco for my recent tire replacement, but read that they refuse to install anything other than the original size. Having found the Integrities to be sadly lacking in grip, I wanted a different tire in a larger size, and was more than willing to give up a bit of mileage for improved safety. Now they're not even willing to change tires, let alone sizes? I'm not sure insisting on installing such a poorly rated tire is in their customer's best interests.
  10. Picasso Moon
    Picasso Moon Member
    117
    Phoenix, AZ
    I had Costco replace the stock Integrities with Michelin X Radials just about a year ago and really didn't see any hit in mileage at all. At the time the tires were replaced I was averaging 56.6 mpg over the life of the car. As winter came the mileage went down as usual but now 1 year later my lifetime average is right back up to 56.6 mpg.
  11. Patrick Wong
    18,199
    6,464
    Hi Tom,
    Actually Costco does not sell Goodyear brand tires (at least in my area) so the alternative to Michelin would be BF Goodrich - Traction T/A or BF Goodrich - Premier Touring.
    Costco Tire Center - Error
    The pricing is better than Michelin X. I'm not sure that either of those choices would be better than the Michelin X tire with respect to rolling resistance.
    Regarding the original post, I think that it is good that the Costco staff tried to make the OP aware that there may be an mpg hit with new tires.
    Regarding hyo silver's comment, given our litigious society, it is quite reasonable for Costco to refuse to install a tire that does not comply with the auto manufacturer's spec. I've used Continental, Bridgestone, and now Pirelli 185/65R15 tires on my 2004; all have provided excellent traction and met my needs (and were all better than the original equipment Goodyear Integrity tires).
    Classic requires special XL-load rated tires. Costco was one of the first major retailers to recognize this, while other tire retailers had no problem selling their customers standard SL-load rated tires of the same tread width. After Costco stopped selling the correct Potenza tire, they refused to sell replacement tires for that car. I respect that decision.
  12. A. B. Hair
    A. B. Hair New Member
    57
    Rural area called Powdersville, 10 miles out of Gr
    I did have a loss of mileage for about 1000 mi. I can't tell any difference now. I got Michelin Primacy MXV. I got the same 185 size
  13. Ian MacDonald
    51
    Benica, CA
    I'm pretty sure they would have simply let me cancel the transaction and go elsewhere to get replacement tires. Costco only offers a couple of tire models currently for the Prius and the Goodyear Integrity is not available from them.
    I was actually happy that they made the effort to let me know about a possible issue. I would have been more concerned if they took a stance to refuse to install anything but OEM replacements. I could imagine some corporate higher-ups declaring that they don't want the hassle and expense of dealing with unhappy customers returning tires. But with Costco and their very liberal return policies I can't really see that happening.
    Cheers,
    -- Ian
  14. Ian MacDonald
    51
    Benica, CA
    What I thought was curious was that the warning I received was not substantiated with anything. It was just that they were aware of some 'issue' with a reduction in fuel economy that they did not yet understand.
    This just goes to show that we'd all be better off if the tire industry was more forthcoming regarding tire parameters that affect fuel economy. There is no standard for which to make a comparison in this regard. It's all hidden away in manufacturer's proprietary data with only vague marketing speak to help you distinguish one tire from another. Right now the best information we seem to have are these anecdotal accounts of folks using various replacement tires.
    Cheers,
    -- Ian
    William Redoubt likes this.
  15. Patrick Wong
    18,199
    6,464
    Hi Ian,
    Is it possible that the warning resulted from Costco tire center managers receiving numerous complaints from Prius owners who noticed that their mpg with new tires was ~5% worse, compared to almost-bald Goodyear Integrity tires? :confused:
    ETP likes this.
  16. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    How about Big O tires? I asked the tech there to inflate my stock GY's to 40 front 38 rear, he said that he wouldnt do it because it would hurt my mileage.:rolleyes:
  17. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    If you are satisfied with the Integritys, you can probably get a better price for them than other "premium" replacement tires which might last longer. But 42K miles is plenty good. Integritys are relatively low price--probably because they are an OE tire in many new cars, and Goodyear makes a lot of them.
  18. patsparks
    10,664
    567
    Adelaide South Australia
    You must have read a different original post to the one I read. I read they told a customer there would be a reduction in mileage after new non standard (read non low rolling resistance) tyres are fitted. Can't fault that.
    I read another post which implied Costco won't go into the realm of the unknown by fitting oversize tyres that a car was never designed to have fitted. If only there were more responsible corporate citizens like this.
  19. hill
    8,070
    I got good news for you (all). First, finding a tires rolling resistance rating is like finding out secrets at area 51. Search long and hard (as I once did) and evenually, via enough google searches they (tire rolling resistance charts) will turn up. Why are manufacturers so secretive about it? Simple! Once you see that the ones that get the best mpg's are not necessarily the ones you'd buy, a lot of brands would dry up .... especially with gas prices spiralling ever upward.
    The michelin hydroedge (also available during the costco sales) has one of the lowest rolling resistance (that's a GOOD thing) rating. Their rating is certainly better then the stock goodyears. And as far as wear? Forgetaboutit !! The integrities? we had to dump then in under 15K miles. Meanwhile, somewhere between 70K & 80K on the odometer ... you can hardly tell they've worn at all.
    So costco says beware? Woooo :p let me give costco a hint:
    I didn't get THIS kind of mpg's driving on goodyear's ~
    Oh btw, Costco will ALSO tell you it's Baaaaahhd to run your tire pressures in the 40 psi range. But hey, if you prefer Costco's advice ... be my guest!
    :whistle:
  20. Ian MacDonald
    51
    Benica, CA
    That would be my guess. I know that the revs/mile of the new Michelin X's are a bit less than new Goodyear Integrities (851 vs 855). I wonder how much more difference there is after the Goodyears are significantly worn down? By my simplistic calculations, with the Goodyears worn down to 2/32 of an inch, the revs/mile ends up around 873. Perhaps this is at least part of the cause of the apparent drop in fuel economy after the switch.
    Cheers,
    -- Ian
