Could a P1121 actually be TPS issues?
Discussion in 'Gen 2 Prius Main Forum' started by eljefino, Feb 13, 2020.
  1. eljefino
    eljefino Junior Member
    43
    24
    Maine
    Just got this car, 2006. Had P0420 cat (fixed), P1116 and P1121. Put in a Dorman (yeah I know) coolant control valve. Still throws P1121 shortly into warmup.
    I drained 3/4 gallon of coolant removing the old part and refilled 1 gallon, using the relay jumper to refill the thermos and bleeder valve appropriately. Am pretty confident it's full. Heat doesn't work though.
    Looking at my techstream data, it shows a desired TPS voltage of 0.7V at idle, TPS 1 reading 0.7, and TPS2 at 2.5 volts.
    I know "hear hoofprints, think zebras" but do I have more work with the CCV or should I move onto the throttle body?
    I have an 05 I can borrow parts from.
    Next step is to backprobe the CCV connector while running the techstream valve position commands.
  2. ChapmanF
    17,347
    Um, is there any reason you even think there is a throttle body issue?
  3. eljefino
    43
    24
    Maine
    Because TPS has redundant sensors and P1121 could also be throttle body issues according to the techstream description (and generic one).
    Never minding, though, as the coolant valve only makes 2.71 volts in positions 4 & 5, and 2.50 at position 3, so it's a bad new part.
  4. ChapmanF
    17,347
    Negatory on P1121 meaning anything but the coolant valve. If you look it up in the repair manual there is no confusion.
    It's in a manufacturer-controlled range of codes, so if Toyota wanted it to mean throttle something something in some other car model they make, they could, and that could explain generic lists or Google getting it wrong, maybe even Techstream (though that would be a bit embarrassing, since Techstream knows what car model it's talking to). But in a Prius, it's the coolant valve.
    I'm not sure what you're getting at with TPS having redundant sensors ... yes it does, and I think they are arranged to read complementary values, where the pair of numbers you reported would probably be normal.
  5. eljefino
    43
    24
    Maine
    I was thinking that the TPS would have two potentiometers reading very similar readings.
    Finally got the correct toyota part installed and, wowsers, it works correctly, who knew?
  6. ChapmanF
    17,347
    Yeah, it has tended to be Toyota's practice to build in two potentiometers that traverse the 0–5V range in opposite directions, and the ECU confirms that the readings are mirror images. Sometimes they'll use a different sensor technology than actual potentiometers, like Hall effect sensors, but still keep the dual-opposing-signals strategy. I guess that does make it easier to catch the sort of problem where both signals get shorted to +5 or to ground.
    The Gen 1 Prius did use actual potentiometers in several places (accelerator position, steering torque, and HVAC flap positions), and any old enough Gen 1 has probably dealt with at least one of the related nuisances when the pots became electrically noisy ("Big Hand Syndrome" when it was the go pedal, "steering gear jitters", or "no, that wasn't a mouse in the heater" from the sound of the flap servos jittering around). By Gen 3, all of those three had been replaced with non-potentiometer sensing technologies. I think Gen 2 still had real pots in the HVAC servos.
    Congrats!
