Could I install a head unit from a Prime or C to get car play in my V?
Discussion in 'Prius v Audio and Electronics' started by JJak, Aug 14, 2021.
  1. JJak
    JJak New Member
    Asheville, NC
    2013 Prius v wagon
    I'm curious if it's feasible to install a head unit from a newer Prius to get Carplay functionality or if I should just install something aftermarket?
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Aftermarket. Newer Prius head units are custom built for the dashboard.
  3. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    The OEM units for a Prius V are unique to the Prius V. Notice how the sides of the unit make wide "V" shape, on a Prius V. On other Toyota Head units, the sides are almost vertical. So there is no interoperability between the V and other Toyota models.
    That said, a 2012-14 Prius V (Faceplate 5701x) can accept head units from a 2015 or 2016 (Faceplate 51005x). There are no Prius V units that support Carplay. It is not easy to upgrade, as the GPS and Antenna connectors are different. Also, for some crazy reason, the back-up camera plug fits, but the wires were moved around. A 2017 head unit (51016x) supports Alexa, but to my knowledge, it cannot be put into a previous year Prius V.
    This is all described in great detail in this thread by Kepik.
    Retrofit Facelift Model (2015+) Head Unit to Pre-Facelift Model (2012 - 2014) | PriusChat
