Coupon codes from a plugin survey
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Totmacher, May 14, 2013.
  1. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    Just took a Plugin survey and at the end they gave away 2 coupon codes.
    Pretty pathetic codes but I searched and no one had listed them yet...
    Coupon Codes
    Thank you for completing the survey. As a token of our appreciation you may take advantage of either of the following discount codes good for $50 off select Electric Vehicle Supply Equipment (EVSE) from the following two providers:
    Clipper Creek
    Code: CCSEPEV13 (all capital letters, no spaces)
    Good for $50 off the price of an LCS-25 (one use per customer)
    Valid thru: June 7,2013
    AeroVironment (sold through Amazon)
    Code: CCSE2013
    Use the following link to shop: www.evsolutions.com/shop
    mrbigh and Tracksyde like this.
  2. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Which survey did you take, assuming you can hare? I did a bunch of EV related surveys as well but no coupons, so I guess I didn't do this one.
  3. CharlesH
    2,796
    1,163
    Roseville, CA
    Those are from California Center for Sustainable Energy, which handles the California Clean Vehicle Rebate Project (CVRP) ($1500) for the state.
  4. Electric Charge
    545
    133
    Syracuse, NY
    Ah ok, in that case, I'm out ;) Thanks!
