cowl to windshield seal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Aug 26, 2023.
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Hey guys,
    There is a plastic seal that goes on top of the cowl assembly where it touches the bottom of the windshield.
    It is some sort of a seal but not made of rubber; more like a plastic and it snaps onto the cowl at the top edge.
    And this piece is falling apart in my 2010 Prius. It is cracked everywhere.
    I looked for the part number for this item for days and I cannot find it. My fear is that it is not offered separately from the cowl assembly which costs hundreds of dollars. :eek:
    Am I correct?
    If so, what are my options?
  2. Mendel Leisk
    42,323
    #2 Mendel Leisk, Aug 26, 2023
  3. iskoos
    415
    254
    Orlando, FL
    Refering to the tiny strip along the top edge of the cowl assembly.
    My finger is pointing it in the picture.
  4. iskoos
    415
    254
    Orlando, FL
    I found the image you posted and tried every possible part number but couldn't find it.
  5. Mendel Leisk
    42,323
    Yeah suspect it’s not a separate part no, for just that rubber top strip; you need to buy whole thing. Check with a local Toyota dealership parts department to verify?
  6. iskoos
    415
    254
    Orlando, FL
    How nice (and profitable) is it for Toyota to sell the whole thing for a few hundred $$$ when you only need that plastic strip that is worth just a few $$$.
    If a part is removable (it is in this case), it should have its own part number and be available separately.
  7. Mendel Leisk
    42,323
    I took a look at one of the small end pieces; I think they’re similar? Indeed the rubber edging slides in, locks. Unfortunately though, looks like they did some sort of heat crimping at a couple of spots. Does the main piece also have those? Seems unnecessary: the strip would be very stable without the heat crimp, can barely shift anyways, and yeah, frustrating.
    #7 Mendel Leisk, Aug 30, 2023
  8. iskoos
    415
    254
    Orlando, FL
    Yes, I realized those heat crimps, but those can be worked out easily. That plastic material is severely deteriorated in my car. It falls apart when I touch it.
    What do I do now? Go buy the whole thing new and pay over $200? This is ridiculous.
  9. Mr_Dobalina
    Mr_Dobalina New Member
    I am facing this same issue. What did you end up doing?
