Cradle for EVSE
Discussion in 'Prime Plug-in Charging' started by mveras1972, Aug 31, 2019.
  1. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I want to mount my EVSE on the pictured location. However, I don't want to fix it to the pole. I want it to be removable because I want to have the EVSE hanging there only when charging. After charged, I will store the EVSE back in the storage compartment in the Prime.
    I am looking for some sort of cradle where the EVSE can be just be placed in it. I don't want to hang it by the cables.
    Any ideas? I've been looking all over and all I can find are hooks to hang the cable.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Velcro...
    Rob43 :)
    PS, Where'd you get that great Pigtail ?
    52,395
    you've got a couple eyeholes at the top of the brick...
    Raytheeagle likes this.
  4. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I may consider the eyeholes if I can't find anything else. Basically, a couple of tiny hooks on the pole and the EVSE will just hang there. Velcro will come off quickly with the weather.
  5. bisco
    52,395
    is there wood inside the pvc post?
  6. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Yes.... there is a 4x4 treated beam inside.
    While searching images online, I came across this picture. I've seen something similar at Home Depot or Lowes. I may pay a visit tomorrow to see what I can find. Of course, my version of this will have to have the hooks closer to each other because it needs to go vertical.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    If the post is substantial enough, I’d use a couple of heavy duty tool hooks;).
    They are very cost effective at Harbor Freight and would lead to easy install and removal of the plug as needed(y).
    Prius from Dad likes this.
  8. bisco
    52,395
    i used a nail and one eyehole. not pretty, but effective
  9. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    hmmmm.... now that I think about it, the hooks won't support the brick from the sides, only from the bottom and it may not be stable. I may have to have something 3D printed at work.
  10. bisco
    52,395
    your ocd is showing :cool:
  11. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    LMAO! You're absolutely right! LOL :LOL::LOL::LOL:
    bisco and Raytheeagle like this.
  12. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Heres the one is use for the base to cradle the brick:
    Heavy Duty Tool Hook
    Then something like this for the above brick to hold it back:
    Heavy Duty Utility Hook
    If search a bit more, but that would work and allow for flexibility (y).
  13. bisco
    52,395
    and you can tell that ray is an engineer, and i'm just a poor weekend warrior :whistle:
  14. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Poor:whistle:?
    Or is that another colloquialism (y).
  15. bisco
    52,395
    good question. poor in ability? or motivation :unsure:
  16. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    I was browsing for tool hooks as well. Interesting idea.
  17. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Since your retired, my money is on motivation ;).
    I can’t wait to have that problem(y).
  18. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Those would work;).
    And cheap enough that if you don’t like the result, that won’t be a mental barrier for living with it(y).
    mveras1972 likes this.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  20. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    #20 Raytheeagle, Aug 31, 2019
