Cranks but doesn't start after overheating
Discussion in 'Gen 3 Prius Technical Discussion' started by Alex_Texas, Feb 19, 2024.
  1. Alex_Texas
    Alex_Texas New Member
    Dallas, TX
    I have a 2010 Prius 194k miles.
    I got the red temperature light and CEL turn on. Felt power loss during acceleration and no heat blowing. Scanner said it’s a bad engine temp sensor. I was low on coolant.
    Filled the reservoir to the line. The temp light started coming on while driving on the freeway.
    Suddenly steam started billowing from under the hood. I pulled over to find the Y connection on the coolant burst open.
    Next thing I did was dumb. I tried to drive 2 miles to auto store. A mile into the drive the car turned off, all lights turned on and I just rolled until I came to a stop and towed the car home. It wouldn’t start until it cooled off.
    Now it turns on but HV battery only. The engine cranks for 7 seconds but does not start.
    it turns over smoothly. Almost don’t feel any pressure when rotating it clockwise.
    Replaced the temp sensor.
    Cleaned MAF sensor, throttle body and fuel injectors. Injectors were filled with gunk.
    Checked fuses. Removed terminals from battery for 30 mins. Battery is low but I jump started and trickle charging it overnight.
    CEL shows 3 codes:
    P0117, P3190 & P3191.
    It still doesn’t start. Just cranks and only stays on on HV. Trying to minimize starting it. Any thoughts on what I can check to get it running again will be greatly appreciated!
  2. Alex_Texas
    Dallas, TX
    Replaced the spark plugs last year. Had EGR cleaned last year. Used Lucas fuel injector cleaner 2 gas fills ago.
  3. Brian1954
    Brian1954 Senior Member
    2,286
    909
    South Central PA, USA
    The car overheated because the engine water pump was going bad. It needs to be replaced before you drive it again. There probably was not anything wrong with the engine coolant temperature sensor. It sounds like you severely overheated the engine.
    What is the level of charge in the hybrid vehicle (HV) battery?
    Now, the challenge is getting it started.
    Alex_Texas likes this.
  4. Mendel Leisk
    41,602
    EGR ever cleaned?
  5. Alex_Texas
    Dallas, TX
    The water pump can go bad without giving a code or making any symptomatic noise?
    Water pump is coming tomorrow.
    Temp sensor can be good even if CEL says it’s bad?
    Can a bad water pump cause the engine not to start?
    Please read 2nd post, I added what has been done including EGR cleaning.
    #5 Alex_Texas, Feb 20, 2024
  6. Mendel Leisk
    41,602
    ^ see you’ve disclosed. Still, you’re at 194k now, well into the head gasket danger zone, and the cleaning was late in the day. You did it yourself, everything including intake manifold?
  7. ChapmanF
    18,281
    P0117 doesn't say "the temp sensor is bad". How would the car's computer be able to know that? P0117 says "the resistance I'm reading of the temp sensor is out-of-range low." The computer can tell you only that; it can't tell you why.
    The temp sensor is a negative-temperature-coefficient thermistor—the hotter the coolant, the lower the resistance—and the resistance will be out-of-range low whenever the coolant is 140℃ or more. So if the engine was severely overheating, the sensor and the code could just have been telling the truth.
    Alex_Texas and Brian1954 like this.
  8. Alex_Texas
    Dallas, TX
    O Reilly tech initially ran the codes and told me temp sensor is bad. Can’t trust everybody.
    I’m hoping once I replace water pump it’ll start. What if it doesn’t?
    I had a shop clean it while it was there last year. Can’t recall what they cleaned but EGR they said got flushed out and didn’t have much carbon they said. How can I tell if head gasket is bad? Higher RPM?
  9. Mendel Leisk
    41,602
    Boroscope inspection of combustion chambers, preferably with cooling system pressurized, can reveal coolant tears making it past head gasket into cylinder, and unusually clean piston tops, the latter again due to coolant getting in.
    Also some symptoms: dropping level in engine coolant reservoir, and knock/shake during cold starts, when car has sat overnight.
  10. Brian1954
    2,286
    909
    Yes, that is correct.
    I do not think so.
    A bad water pump probably is not related to your not being able to start the car. I would fix the starting issue with the car before replacing the engine water pump.
    I will ask this question again.
    #10 Brian1954, Feb 21, 2024
    rockson and Mendel Leisk like this.
  11. Alex_Texas
    Dallas, TX
    Thanks for the info Mendel! I’ll look into once I get the car running, hopefully
    When I just started it was almost full 80%. After about 10 mins it dropped down to 20% (2 bars I believe).
    Do y’all have any idea what can be causing it not to start? How can I go around diagnosing with no more codes showing up? Hoping I can get some progress before I give up and take it to a local recommended shop.
  12. ChapmanF
    18,281
    The world is full of people whose understanding of car trouble codes never got past "the one-liner next to this code has the words 'temp sensor' in it, so it must be telling me to replace the temp sensor", and a lot of those people work in parts stores or shops.
    Word to the wise: every trouble code has a section in the car's Repair Manual specifically about it, and every one of those sections has a box part-way down the page headed "detection condition", and the words in that box tell you exactly what the car's computer has noticed when it sets that code. The code doesn't 'mean' anything more or less than what that box says. (The rest of the section in the manual will be ideas to help you pin down why the computer might have seen what that box says.)
    As that box, for P0117, just says "short in engine coolant temperature sensor circuit", that leaves a human to figure out why the computer might have seen a short (very low resistance) there. Usual culprits can be mice chewing the wiring. The sensor itself would be a very unlikely cause: thermistors just don't go bad much.
    But seeing further down the page that the possible-short resistance reading would correspond to temps 140℃ or higher, and knowing the engine happened to be severely overheating just then, makes room for the possibility that the sensor and the wiring are all fine, and it was just reading the temp it really saw.
    Toyota Service Information and Where To Find It | PriusChat
  13. Mendel Leisk
    41,602
    Moral of the story, get your codes from O'Reilly, but do you own diagnostics?
  14. ChapmanF
    18,281
