Crashed, need AC condenser recommendations
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by darkleafar, Jun 7, 2018.
  1. darkleafar
    darkleafar Member
    232
    Houston TX
    I rear ended someone and I'm going through a body shop instead of insurance. However ac condenser was damaged and need to replace it. Auto zone sells one for a beautiful 470 dollars, while Amazon had them for 70 bucks. What am I missing here? I wanna buy something reliable.
    I've got a prius V three 2012
  2. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    My ac compressor had a short last november and caused a check hybrid system. I was able to pinpoint my problem using techstream. I bought my condensor from amazon for $50.99 mid november last year. Prices are up because it's summer i guess. Mine is still holding up well and came with negative vacuum. I replaced my ac compressor (used on ebay with 60k miles) condensor, 3 cans of r-134a and hybrid compressor oil all for 166$.
    If it can hold vacuum, it will hold refrigerant.
  3. Mendel Leisk
    41,882
    I should know better than to tangle with you sir, but anyway: something might be tight with vacuum applied, but not with pressure, ie: what was sucking in is now bulging out. And when bulging out it's more leak prone??
    Maybe in practice that's never gonna matter, but just a thought.
    ITBland likes this.
  4. danlatu
    533
    1,367
    maryland
    In hvac we pull vacuum for two reasons. It removes moisture from the system and ensures no leaks before adding refrigerant. I pull vacuum on the entire system when it is empty for about 30 min. High and low pressure gauges are left on for about 10 minutes to check to see if system holds negative vacuum before adding refrigerant. The condensor and ac lines are made of aluminum and will not bulge.
  5. Mendel Leisk
    41,882
    Yeah I was thinking too, vacuum was to evacuate the system. I've no experience with ac, just having a brain fart.
  6. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    What is "negative vacuum"?
  7. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
    Got mine from Rock Auto $50.00
