Crashed Prius C - How to Release Steering Lock?
Discussion in 'Prius c Main Forum' started by Phildo, Jun 1, 2021.
  1. Phildo
    Phildo Active Member
    139
    110
    Perth, Western Australia
    i-Tech
    I've recently bought a crash-damaged Prius C but the steering is locked. The airbags have deployed.
    What does it take to release the steering?
    GraysOnline - 29121834.jpg GraysOnline - 29121835.jpg GraysOnline - 29121837.jpg
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,500
    Taylors, SC
    I don't really know about the Prius c, but there is apparently no physical steering wheel lock on Gen 3 and possibly other Prius models.
    Curiously, why would the steering wheel need to be locked in a crash?
  3. Leadfoot J. McCoalroller
    8,149
    7,652
    Pennsylvania
    2018 Prius c
    I believe the One and Two trim have a simple mechanical interlock on the ignition- turn the key or remove the lock cylinder.
    Three and Four will have the electromechanical lock system for electronic keys. I don't know the procedure for those.
  4. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    Did you managed to remove the lock?
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Pull hard right and power on
  6. Morpheous
    Morpheous Junior Member
    Australia
    ----Australia----
    Did you get the steering lock released? I believe push power button and pull hard on the steering wheel both ways to release it.
