Crazy 199 MPG when going down big decline
Discussion in 'Gen 4 Prius Fuel Economy' started by robsnyder20, Feb 7, 2017.
  1. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    SP32-20170207-223234.jpg Standard Gen 4 Prius not Prime
    I came back from a trip and had a couple questions about using B and going down hills. My RPM was up high, as expected to hold speed which worked very well and on my torque app, it shows that I was getting about 50 MPG and using fuel, but somehow, my car indicated that I got 199 for the trip and instantaneous downhill. I was at the top of a peak in the smokies, called Clingsmans dome, coming thru Gatlinburg, TN into Pigeon Forge. Here is a pic of the readout. I am from Florida so not used to elevation changes, but I consider the prius suspect for not indicating MPG correctly upon B decel.
    I did reset the trip and can confirm even though the engine was near redline 4+k (thru torque app) and showing a .5 to .7 MPG fuel use and 40 - 60 MPG, my car said I am getting 199 instant.
    RCO and krmcg like this.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I do not own a Gen 4 and this is just speculation.
    There are two different ways to measure MPG in this scenario.
    One would be to only consider gas used times miles driven.
    The other would add the charge stored that will later become free energy.
    RCO likes this.
  3. robsnyder20
    374
    301
    SW Florida USA
    For whats its worth, the opposite way going up I got 21 MPG the steepest area of the climb (which was roughly 8 miles or so)
  4. Mendel Leisk
    38,727
    Think of it like an investment portfolio: don't sweat the momentary ups-and-downs.
    RCO likes this.
  5. gher
    gher Junior Member
    Tacoma WA
    When going downhill like that in B mode, there is really no fuel going through the engine, it's just an air pump for resistance, so the instant mileage will read the same as if you were running purely electric. The max the mileage display will read is 199.9 MPG, so that's what you see since there was no fuel being used.
    I live about a half mile from my favorite grocery store, and when I drive to it in good weather after the car is warmed up the ICE never turns on, it's all electric the whole way, and my instant mileage shows as 199.9 MPG in that instance.
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Cornwall also has some steep roads and I have found that when you get this maximum mpg 199.9, once you start cruising again with ICE running or climbing another hill, the mpg soon begins to drop to a more realistic mpg.
  7. robsnyder20
    374
    301
    SW Florida USA
    Thanks for your input everyone. I actually looked into it on other generation threads a few hours after posting and the consensus was that it used no fuel. I really liked using the DRCC for driving but didn't like how the engine would rev up for a normal stop. Now I know it doesn't use fuel when slowing down for a light.
    RCO likes this.
