Crazy shenanigans at the dealership. Input anyone?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CamDiggy, Aug 31, 2012.
  1. CamDiggy
    CamDiggy Junior Member
    26
    Austin, TX
    So, I have been reading these forums for a while just never posted and thought I would give it a go. I have a 2007 Toyota Prius with 120k. This week, I decided to get the water pump recall done on my Prius as I was advised on my last few visits to my local Toyota dealership.
    During this process, they called me and told me the whole line about we would like to do
    -Throttle body cleaning
    -Transaxle fluid drain/fill
    -complete tune up
    -airflow meter cleaning
    -replace various filters etc.
    I gave them the go ahead for those and figured I would have them do an oil change as well as it was already there.
    Then, the rep proceeded to tell me the first inverter water pump was making a terrible noise, so they had to replace the replacement. They needed and extra day or two as well is what they told me.
    I called back a few days later and they said all was well and they were just finishing up. So I headed down to go get it, it was idling very roughly and there was coolant all over the front grill and ground when they brought it out. I pointed all this out so they had a "master technician" take a look at it. They said all was well and that after these throttle body cleanings they all idle roughly and that it will go away. So I head home from the dealership at 7:30pm or so and all the hazard lights/warning lights turn on as I approach my house. Turned it off, waited a bit and they all disappeared after about 20 minutes. Turned the car on and it drove normally (except for the rough idle) the block and a half to my house. Proceed to wake up for work this morning, drive a block and all the lights go off again and I limped the car to a parking lot. Called them up and they sent a tow truck as the Prius would not go in to drive after this incident.
    They are currently keeping the car but they stated, the code they got from the error was something about the hybrid inverter failing and had nothing to do with the work they did. I got the definite feeling they were trying to pass the buck to me. Not sure if they could be related or if any of this sounds familiar to anyone but all input is welcome!
  2. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    The inverter failed probably from coolant being missing, or too much air in the coolant, or they test drove it with the first pump which wasn't working at all, probably threw a code, they said o-SHI and put in a new pump. But the inverter overheating is directly related to the coolant pump, which is why there was a recall and why you took it in to be replaced.
    But it also depends on the exact error they are getting. But not related to the rough idle, or probably any of the other work they did. But if there was air in the system that wasn't bled, or the first pump wasn't ever pumping it could have damaged the inverter. Or the new pump they sent you home with wasn't working and you damaged the inverter from overheating it.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    What Joe said and lets include they probably overfilled the hell out of the oil too which sometimes makes the engine run rough.
    Idling rough after a throttle body cleaning? Hardly. Should run better than ever if done right. They probabaly left the MAF plug unplugged.
    Who knows what these idiots did. God I hate car dealerships.
    But this could turn into a complete nightmare so pay attention. From here on out its important you get ALL the codes from them whenever you see the dash lights come on as these are the clues to what they botched up. I would demand to know the codes that have been thrown so far so we can see what they messed up. Post them here.
    They are clearly incompetent and have caused all these issues. Do not take there word on anything they say and do not pay another dime. Coolant all over the car is ridiculous.
    51,155
    please give us the location and dealership to help save someone else from going through what you have, thank you.
  5. CamDiggy
    26
    Austin, TX
    I really appreciate all the help! I will ask them for the codes in the morning, hopefully they actually tell me them. I will keep this thread updated with any new information I get.
    Anyone have a good recommendation for a Prius mechanic to get this checked out after this in Austin, TX?
  6. Patrick Wong
    18,200
    6,493
    It sounds like the inverter coolant pump replacement was botched which caused the inverter to fail. The pump is responsible for providing an adequate flow of coolant to the inverter. You have stated that the first replacement pump failed. Hence it is very reasonable to infer that the inverter failure is a direct result of the pump failure.
    Regarding the rough idle, perhaps the tech did something wrong with the spark plug change, such as not tightening a spark plug, or failed to reconnect a wiring harness connector to a spark igniter, or contaminated the mass air flow sensor with throttle body cleaner. The car should not have been released to you with that problem, not to mention allowing the pink coolant spill to remain on your car's exterior.
    Unless the facts change materially from what you have described, if the dealer does not accept responsibility for the inverter failure you should complain to the Toyota Customer Experience Center.
    Good luck, I think you will need it.
    cwerdna likes this.
  7. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Yeah i didn't even think of that if they cleaned the MAF, they could have damaged it (physically or with solvents), or the connector or left it unplugged, it is right in the front on the box you change the air filter. Or seriously overfilled oil. (lol, never Prius change oil at a Toyota dealer!!!)
    I also wonder if the first pump made a terrible noise because some idiot clamped off some hoses to save time refilling the coolant and left the clamp on and killed the first pump, and probably hurt the inverter from no coolant flow. Look for marks on the rubber hoses near the pump or around the inverter.
    I would speak to a service manager and say
    - you want the to examine the 1st failed inverter or at least ask why they had to remove it.
    - ask why if they had it so long they couldn't wash the car or at least remove the coolant spilled all over it.
    - Check the oil and if it is over the full mark, you want them to drain out 1 Qt. (There are TSB about danger of overfilled oil in Prius).
    - You want them to test the MAF in case it was damaged in cleaning.
    - Check on the bill what ATF fluid they used changing the transaxle fluid (I'm assuming they used ATF WS since it is the most common), but wouldn't hurt to double check from the guy that did it.
    - You want to speak to a regional manager about a new Inverter depending on the codes and if the dealer recommends replacing it, because it sounds like they put in a faulty pump (the item of recall) and ran it causing the problem in the recall you brought it in to prevent from happening in the first place.
    philmcneal and edthefox5 like this.
  8. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Good one Joe. Op do not fall for the Inverter has failed bull. That's really expensive. Give us the name of the dealer please.
  9. CamDiggy
    26
    Austin, TX
    So, after an entire day at the dealership (Champion Toyota Austin)...they finally said that it was an issue with one of the spark plugs, and the wiring harness for the inverter. They apparently got it all sorted out and didn't have the codes for me (surprise surprise). I have been driving it all day just to make sure all is well, and it seems to be. I am a bit concerned so I plan on getting a different mechanic to look at it.
    Any other suggestions from here? Also, anyone know of a good Prius mechanic in Austin, TX or which forum to ask in?
    Also, thought I would say the didn't charge me for any of the cleanup work/tow fees thankfully.
  10. Patrick Wong
    18,200
    6,493
    If your car doesn't demonstrate any driveability symptoms then you should be good to go.
    I suppose you are not going to rate this service experience as EXCELLENT when you get the survey.
  11. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    You should contact Toyota Customer Experience Center. So you couldn't even get any manager there to go and find out what the codes were? They don't document anything when doing these repairs?
    The coilpack / sparkplug seems likely, and I suppose they had to remove the inverter to replace the pump? I guess they don't do it the luscious garage way.
    It all depends what the codes were and it is possible all that was wrong was a connector something to the inverter...
