Creaking when I turn wheel (while brake is applied)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Panagiotis Garbis, Jun 5, 2021.
  1. Panagiotis Garbis
    Panagiotis Garbis Junior Member
    22
    Chicago
    Hi All,
    Whenever I am back into my parking spot ( which is a bit elevated ) I usually have my foot on the brake so I can stop and maneuver the wheel. Whenever I do so, I hear a creaking sound that comes whenever I turn the wheel from one end to the other, the front creaks a bit while the back creaks significantly louder.
    Any ideas what this could be? Every mechanic says the car looks okay but this sound doesn't sound normal and that there are no points where Priuses can get lubricated (unlike older cars)
    An FYI, I hear NO sounds whenever turning regularly (without foot on brake)
    Thank you!
    52,390
    maybe just rusty brakes.
    try running up to 30mph on a quiet road and throw her in neutral. gently apply brakes to burn off the rust.
    then try parking to see if there's any change in sound
    how many miles on her?
    is there any sound if you back up and brake at the same speed without turning the wheel?
  3. Panagiotis Garbis
    22
    Chicago
    Bisco, I love how I know you'll reply! You are always so helpful.
    Unfortunately, I have tried that so many times. I even had the front brakes replaced and it is still there. The creak happens when I have my foot on the brake and I turn my wheel from one side to the other. I had the brakes inspected and 3 mechanics say they are fine.
    2015 hatchback 5 with 40,100 miles
    Raytheeagle and bisco like this.
  4. Panagiotis Garbis
    22
    Chicago
    Also, I only hear the sound when I'm on some sort of incline, decline
  5. bisco
    52,390
    tough one, let me think some more (n)
  6. Panagiotis Garbis
    22
    Chicago
    Some folks are saying its normal for the Prius to creak when foot is on brake and turning but....I want to put this to rest and not pay for services that aren't required. I already spent 800 trying to nix this sound..
  7. bisco
    52,390
    i'll try it myself. i know mine does creak as i press and release the brake pedal at slow speeds.
    i have always assumed it is the pads grabbing and releasing. it seems impossible to hold a constant pressure.
  8. Panagiotis Garbis
    22
    Chicago
    Try it on an inclined driveway of sorts. I press the brake firmly and turn the wheel from one end to the other and once there is a bit of resistance, there is some creaky noises. If I turn left, I hear it on the right side. Vice versa.
  9. bisco
    52,390
    hang on, you are holding the brake so the car isn't moving?
    and it only creaks when you get to the stop limit of the steering wheel?
  10. Panagiotis Garbis
    22
    Chicago
    yes and the creaking begins towards the end...so yes.
  11. bisco
    52,390
    okay, got it. that's not the brakes then. maybe the steering mechanism, but it could be normal. i'll check mine.
    with regular power steering, you get a hiss at the end stops
  12. Panagiotis Garbis
    22
    Chicago
    For sure, thanks Bisco.
    Again, this mostly occurs if I am coming out of a parking spot that is either on an incline or decline. Never, if rarely, does it happen when I am on a regular road. My dad just told me I may be pulling the calipers when the brakes are being locked in and that isn't good for any car....so maybe I am just an idiot. lol.
  13. bisco
    52,390
    if you are turning the steering wheel while not moving, that isn't good for the tires. causes wear as they are spun on the asphalt
  14. Panagiotis Garbis
    22
    Chicago
    Update: The brakes had metallic pads and rotors. They should be ceramic. Also low brake fluid. Sound is gone!
    bisco and Mendel Leisk like this.
  15. Mendel Leisk
    41,901
    Sticking with Toyota parts there’s no surprises. (y)
  16. Prius alpha
    Prius alpha New Member
    Sri Lanka
    2013 Prius Alpha
  17. Panagiotis Garbis
    22
    Chicago
    Wrong type of pads and rotors and low brake fluid. Funny enough - Chicago Toyota said they had redone the brakes and service before I bought the car. Idiots.
  18. Panagiotis Garbis
    22
    Chicago
    The idiots at Northside Toyota in Chicago told me they serviced brakes and brake fluid prior to me getting the car. Such morons. Such a great reputable car company and their dealers are absolute morons.
  19. bisco
    52,390
    got that right, but it's all dealers with few exceptions. nature of the beast. a business built on taking advantage of people
  20. Panagiotis Garbis
    22
    Chicago
    they called me asking to take my car back - offered me 1,000 less than I paid and asked if I wanted to lease a 2021 Corolla....with a check engine light on.
