Creeping forward in D(rive)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LDB, Dec 29, 2015.
  1. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Ok, I get that a regular car with an automatic transmission will creep forward unless you keep your foot on the brake. Why does that happen in our cars when they are in EV mode at a stop? Unless the pedal is pressed to send power to the electric propulsion system why shouldn't it just sit there absent influence from gravity?
  2. vskid3
    vskid3 Active Member
    773
    228
    Because that's what people expect, same reason some CVTs have "gears". Seems dumb to me that the default action is for the vehicle to move, but that's just the way it is. Only way to fight it is to drive a manual.
    fuzzy1 and Mendel Leisk like this.
  3. LDB
    LDB Member
    279
    71
    You'd think if they are willing to go against the grain with that awful reverse beeper they'd be willing to go against the grain and let the car stand at a stop without brake pressure and without creep. I wonder if that's a programmable setting we could change.
    49,479
    no, it can't be changed. but it can be helpful in some situations, where you want to move, while having your foot on the brake 'at the ready'. a fraction of a second lost, transferring from gas to brake can be deadly.
  5. TomasV
    TomasV Junior Member
    52
    Haddon Heights, NJ
    I imagine it being a safety feature too. If you're stopped at a red light, with creeping you'd naturally hold the brake. So if someone rear ends the car you don't go flying into the car in front of you. If we wouldn't have creeping I'm sure a lot of people would release the brake pedal once they are stopped at a light.
  6. Mendel Leisk
    38,720
    It acts as a slight "hill hold" too. No big deal.
  7. bisco
    49,479
    what are the other hybrids, phev's, bev's doing?
  8. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    It allows for one pedal driving in stop/go traffic.
  9. qdllc
    qdllc Senior Member
    1,370
    399
    My take...
    When you are stopped and brakes are applied, no power is sent at all to the transaxle.
    When you are stopped but NOT applying the brakes, the system anticipates a signal to send power to the transaxle. If you listen, you can hear the electric motor "energizing," and the given amount of juice sent to the electric motor will facilitate forward motion if on a level surface. I doubt it's enough to pull the Prius uphill, though.
    When in gear (R or D) but not stopped with brakes on, the drive system is ALWAYS in "stand by" mode...ready to respond the instant signal is received from the accelerator.
    Conversely, it's possible the accelerator never sends a zero value to the computer. So, if not stopped with brakes on, the input to the computer is >0, so a minimal amount of power is sent to the drive system.
  10. fuzzy1
    10,167
    Which is what my household still does. Three vehicles, the Prius is the only non-MT.
    When the old Subaru demanded replacement two years ago, and no compelling hybrid replacements were available, we bought another manual transmission. Fortunately, the local dealer still had plenty in stock and in the pipeline at that time. But it appears that supply flew off the lot very quickly, and has been very sparse ever since.
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Transmission creep can be toggled on/off in a Model S.
  12. Mendel Leisk
    38,720
    Model S? Tesla??
  13. bisco
    49,479
    yeS.
  14. mrbigh
    3,686
    699
    Long Island, NY
    you can upscale your wish to the list of Toyota Customer Care, ............:rolleyes:
  15. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    That wastes battery energy while you're stopped in "D" without depressing the brake pedal. The torque to creep comes from current in a motor. Pressing the brake cuts off that waste of power---as well as assuring the car doesn't roll.
    Much the same applies in "R," although the transitions from slow creeping to stopping and back seem a lot more jerky in reverse.
