critical juncture with my beloved 2005- help me decide!
Discussion in 'Gen 2 Prius Main Forum' started by priusma, Aug 22, 2019.
  1. priusma
    priusma Junior Member
    24
    california
    177 thou miles on my 2005 prius-I replaced the hybrid battery 2 years ago (refurb), then the 12v last year, then the combination meter and spiral cable this year-OH-and a new key fob- thought it was road worthy and ready to take with me on my move to WA from CA but Sunday night the hybrid battery (not sure if that is even what it is called) crapped out. Had it towed to my mechanic who said 3 cells dead, and to replace would be prob around 2500 as he doesn't do refurbs.
    So I've put about 1700 bucks into it this year. Is it time to give it up? I asked the mechanic,
    he sighed and said "well, I can't say, don't know how the transmission is, fluid a bit dirty..."
    He said he'd give me 750 for it now without a battery. What to do? Thanks in advance.
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Will the replacement HV hybrid battery be "New", and supplied by a local Toyota dealer?
    Ask if the HV battery fan will also be cleaned. See if the mechanic will give you the OBD2 codes.
    Did he put the vehicle up on a rack, remove the fill plug, and stick his finger in the hole? :cool:
    Raytheeagle likes this.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Now you see why reputable places "dont do refurbs". You paid presumably a fair amount for this refurbished battery that lasted you 2 years and stranded you at the side of the road where you needed a tow. Worth it?
    You have a car that's worth a few thousand dollars and has been 74% of the way to the moon. Everything on that car that isn't replaced is 15 years old. Only you know how you've taken care of it. If it is worth $1600-$2500 to get it back on the road, then do it. But if it is a beater, it may be time to cut your losses.
  4. priusma
    24
    california
    Yes he will put in a new battery. I didn't get stranded on the road, I was close to home when it happened so was able to park in front of my house. My car isn't a beater, it's been taken care of really really well. Yes the mech. looked at and felt the transmission oil. I do appreciate your comments, just still on the fence. Perhaps 2500 is still worth it, I hope to get clarity on the decision today. If I keep it, it will be living its days as an 'island car' just driving short distances on a small island up north. My daughter wants me to get a Subaru Outback or Forester. Hmmmmmm. More comments or feedback?
  5. JC91006
    16,488
    8,402
    I find it quite unusual for 3 modules to fail at 1 time, I think it's more of an effect to have you sell the car to him really cheap.
    Also why did the transaxle fluid conversation come into play? If it's a failed battery, he just wanted to add more negativity to the car so you'll let go of it? I'd would think if you decide to put a new battery in, this mechanic will try to stop you
    $750 + $2500 = a very cheap car. You can easily sell the car for $4000 in California. You won't lose your $2500
    I know a guy in Palm springs that will pay you $1000 for that car without the battery. And I would pay you $1000 in the Los Angeles area
    #5 JC91006, Aug 22, 2019
  6. VFerdman
    VFerdman Senior Member
    1,152
    1,177
    Western Massachusetts
    I am not sure it's a good idea to use a Pius as an "island" car for short trips. It is simply not meant for that. It's meant to be driven a lot. Short trips will not be kind to even a new battery. If all you need is an island car, why not let this one go and get a Corolla or a Yaris or something that is almost as economical and reliable and has none of the hybrid issues.
    davecook89t and Skibob like this.
  7. bisco
    49,572
    it's hardly broken in. get the new battery an enjoy the next 100,000 miles
  8. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Agreed. I would look around before I bought a Subaru though. They have problems too. A corolla or scion is a safer bet.
    #8 Skibob, Aug 22, 2019
    VFerdman likes this.
  9. PriusCamper
    PriusCamper Senior Member
    11,119
    4,527
    Pacific Northwest, USA
    I'm up here in Washington and will be in California in a couple weeks. A couple years out of a refurbished is a pretty good run and for under $500 I could replace the bad modules and recondition pack you could get some more months of even years out of it. Or for as low at $1650 you can get brand new pack from Toyota dealer and it takes me 2 hours / $100 to put it in and you will have a pack good for 6-12 years that you can even put in your next Prius. As for transmission, I wouldn't be too concerned, it's fairly rare for those to go bad... Private message me if you want to compare locations and schedule?
  10. priusma
    24
    california
    Thanks everyone, your advice was very helpful, I've decided to put a new battery in and keep the car!
    All the best, susan
    bisco and Raytheeagle like this.
  11. bisco
    49,572
    congrats!
    all the best (y)
  12. MilkyWay
    MilkyWay Active Member
    819
    358
    23
    MI
    There is no trans dipstick so I'm curious how he determined trans fluid was dirty. Unless he was giving it a very thorough inspection and undid the bolt underneath to let some drain out?
    I would consider finding a mechanic that won't rip you off. It's like an hour job to remove the hybrid battery and put another one in.
    Not sure what part of Cali you are in but the junkyards must be loaded to the brim out there with Prius parts. I'd go on car-part.com and get a used hybrid with like 120k on it for $600-$700 and see if they will install it for a couple hundred (it will come with at least a 6 month warranty if junkyard is reputable). So less than a 1k job. Something to consider.
    #12 MilkyWay, Aug 25, 2019
  13. MilkyWay
    819
    358
    23
    MI
    It's $60 (in San Diego) to have combination meter rebuilt.
    Or you can get a used one for about $120. Doesn't include the 1 hour labor of removing/installing part (very easy).
    12V is a little over $200 at dealership but can be around $180 installed at PepBoys if I remember correctly.
    Never heard of a bad spiral cable on a Prius so not sure cost of this repair.
    New key fob is $300 at dealership approx.
    Not sure your price breakdowns but the biggest scam is combination meter that is usually an intermittent issue and not serious to drive with blacked out odometer/fuel for a short period of time cause you can just use your GPS on phone to tell you how fast you are going (or guesstimate)...Hopefully you didn't pay to much for this repair. Pretty sure dealership wants $800-$1200 for this meaningless repair that doesn't effect how a Prius functions.
  14. PriusCamper
    11,119
    4,527
    Good decision! Congrats... Let me know if you need any help... I'll be in California in a couple weeks.
