crossed off key display
Discussion in 'Gen 2 Prius Main Forum' started by genalex, Nov 3, 2013.
  1. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
    haven't logged on in years, but loving my '05.
    First time I have seen this and can't find it in manual or knowledge base:
    Started up with smart key in my pocket....everything normal except a dash display of a key with a line across it. Stayed on for a minute or two, then went off.
    Anyone?
  2. thzpcs
    thzpcs New Member
    Parker, Colorado
    That means that it can't see the key. Take a look at the battery in the remote as it's most likely dead
    49,490
    if everything worked fine, you might have a degraded 12 volt battery which will eventually need to be replaced.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    You can check the key by how bright the red led is on the fob when you push the button. Take note of a freshly batteried fob how bright it is.
    That and like Bisco said the 12 may be marginal. If the 12 gets really low it will throw a red momentary red exclamation point on the dash upon boot up. The red exclamation point is the only lamp that does not light upon boot up bulb check. It will if the 12 is below 11.4 volts under load. Thats the only warning you get the battery is ready to leave you.
    Very noticeable.
    Try this:
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    You want the second and third number. Post it here.
