CR's Prius Reliability Rating Drops to Average
Discussion in 'Gen 3 Prius Main Forum' started by jrb451, Mar 5, 2011.
  1. jrb451
    jrb451 Junior Member
    59
    Conway, AR
    CR's Prius Reliability Rating Drops to Average in the 2011 annual Car issue. Looks like "brakes" scored "much worse than average" and "body hardware" "better than average" , next to highest. Both areas scored better in past years.
  2. kevindeschamp
    kevindeschamp Junior Member
    Colorado
    Do you have a link?
  3. jrb451
    59
    Conway, AR
    I read it in the magazine that arrived this week. Here's the link to the on-line version. (You may have to be a subscriber to read it. I do.) Car Model Review - Consumer Reports
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Yep, but ignore the brakes which is a red herring, and the Prius continues to reign supreme. I suspect without proof that the survey results of body hardware mostly represents a more critical audience in that area. People who buy the Prius for its green and tech attributes don't care as much about the occasional plastic squeak than the current demographic that tends to emphasize 'driver experience.'
    In short, same car but different owner group.
  5. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    What brake problem in 2011 are they complaining about?
  6. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Most likely newbe Prius owners complaining about "Braking loss" when a wheel slips at low speed. When they discover that the brakes last 200k miles maybe they will change their minds.
    JeffD
  7. SageBrush
    11,627
    2,530
    Southwest Colorado
    The 2010 recall.
  8. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    CR's target audience is the "average consumer". So any negative experience from what an "average consumer" expects will reduce the ratings e.g. the Prius braking characteristics.
  9. john1701a
    john1701a Prius Guru
    12,753
    5,245
    57
    However, a characteristic isn't the same as reliability.
  10. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    The government is doing the best that it can to discredit the Prius ... so "the car of the year" will be perceived as great. It has been reported on other threads that CR has no choice (by their standards) but to lower the overall rating when a recall has been issued.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I'd guess given the high profile recall of numerous Toyota models, and the hysteria and negative publicity across the board..that Toyota models across the spectrum will suffer a reliabilty ratings drop for this model year.
    It's unfair...but the breaks of the game.
    Actually I think it's a testament to the faith and trust that Toyota has fostered that ratings aren't lower.
    Barring some major unforeseen catastrophe I would expect a rebound next year and with ratings as a whole "moving forward".
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    it is due to the software brake TSB... and CR still calls it their pick so....
  13. macmaster05
    macmaster05 Senor Member
    4,050
    729
    It's quite amazing, despite the bad year Toyota/Prius has had, the Prius is still selling like hotcakes. :)
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    Used 2010s are going to be great buys in a couple of years.
  15. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    The basic problem is that CR's method of establishing a Reliability rating can produce misleading results and, at least in this case, they made insufficient effort to point out why the particular rating may not reflect reliability. A general disclaimer does not cut it.
  16. Papagoose
    Papagoose New Member
    29
    Cedartown, GA
    I had a coworker waving this around at me like a flag as proof that I better get rid of my "piece of junk" before I "get killed or it craps out on the side of the road". I'm not really sure a CR rating of Average when based on a misunderstood brake issue can be considered necessarily to be a bad thing.
    I asked her as politely as possible to shove it someplace uncomfortable.
  17. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    No big, so it gets average rel. rating by CR. People who know Toyota won't worry about that too much ... they will concern themselves with getting a car that does 50 MPGs average.
    Amazing how some people think their conventional cars are all that. They're just like any other car - turn on engine, stays on til trip over. Conventionals are going down eventually.
    People just like to have their extra bit of acceleration from one red light to the next. See it all the time, they speed up too much, then have to brake harder, stop at next light. They have no clue how to really drive a car - for maximum efficiency.
  18. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    CR has lost most credibility with me. Their calling the iPhone 4 unacceptable (antenna-gate) was the last straw for me.
  19. leatherprius
    leatherprius New Member
    Alliston
    Hi Jeff
    I am new today on PriusChat.
    A while back some service manuals were on here
    for download. I can't seem to open the file!!
    Do you know which software program can open
    the 06 to 09??
    Thank you
    Tom
  20. indyV
    indyV Junior Member
    58
    NorCal
    Keep in mind this is their "predicted reliability." Predictions aren't always 100% correct. And they base their scores off of subscriber surveys.
