cruddy mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by capobvious, Jan 6, 2015.
  1. capobvious
    capobvious Junior Member
    Asheville, NC
    Well, this is the 2nd prii i've had. First was a 2010, which was mostly a 20 mi highway commute and avg prob about 45-50mpg. This one is quite different. Maybe a 1.5 mi commute one way, and up a pretty good sized hill. I know all the logical reasons why mpg will and has suffered. But, to get about 35?? seems really low, even for a non warm engine, and having to lead foot it up a hill for 40 seconds. Thoughts?
    walter Lee likes this.
    51,155
    sounds about right to me, sorry.:unsure: why not take a 20 mile drive and find out for yourself?
    what is it, anyway?
  3. capobvious
    Asheville, NC
    thats what i thought!
  4. fuzzy1
    10,335
    That sounds quite reasonable to me.
    On both this and my most recently departed non-hybrid, I figured each full warmup cycle cost very roughly the equivalent of 2 (warmed-up) miles of fuel. I.e. for the old Subaru, which would fully warm in that distance, a 2 mile trip from a cold start would consume the same fuel as 4 miles on a fully warmed engine. That also meant a cold 2 mile trip had half the MPG of a long trip. Shorter cold trips had even low MPG.
    The Prius seems to have a similar total warmup penalty. But since it warms slower (in my area, where the engine shuts down at stops) and doesn't get fully warmed in 2 miles, so doesn't pay the full penalty on short trips. That is why it's MPG after 2 miles is better than just half the figure it achieves on long trips.
  5. bwilson4web
    16,012
    There are pathological trips that make a Prius as bad as an ordinary gasser. Short trip from a cold-start is death but ideal for a plug-in . . . which does not have to be a Prius.
  6. bisco
    51,155
    you got that right.(y)
  7. bwilson4web
    16,012
    Then there is the Top Gear route!
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Sounds right to me. A conventional car would never get even remotely close to its EPA rating in such conditions either. You're spending so little in fuel costs you shouldn't care or you should have bought a BEV or PHEV.
  9. capobvious
    Asheville, NC
    Yea I agree, I was in the market for a volt when I leased this prius. But it was too expensive at the time, and this was the right price. A little less fuel economy is a slight trade off. I still only fill about once a month....maybe
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    How did you lease a Prius for less than a Volt withing the last 2 years? Volt leases are generally $179-$250 a month.
  11. walter Lee
    1,126
    376
    Maryland
    The only way significant way to mitigate the cold start cost of a 1.5 mile trip is to prewarm up the engine with a 400w OE engine block heater before each cold start (or if it is in a heated garage) - depending on the outside driving temperature - there is a point of diminishing returns with respect to warming up the coolant over 60 minutes. Grill blocking won't help fuel efficiency of a 1.5 mile commute one way. At 1.5 miles - dropping your top speed to about 28 mph will probably help your fuel efficient without increasing the time you are travelling significantly. Unlike most gasoline based cars the Prius is optimized to trade off fuel efficiency for very low exhaust emissions during the first five minutes of a cold start. The Prius exhaust emissions are about 1/2 that of a regular car - even during the cold start cycle where most gasoline cars emit 2x their rated exhaust emission, the Prius exhaust emisssion are very low.
    To get high fuel efficiency going up a good size hill on a Prius, a Prius needs a running start before entering the uphill grade. There are two approaches to controlling the throttle when going up hill, non automated and automated. (1) For non automated, a driver put the Prius in normal or pwr throttle mode for the most responsive throttle setting but keeping the throttle down so that the HSI display is never going pass the "C" in the "ECO" capsule marker while the Prius goes uphill . The Prius will likely lose speed as it climbs uphill but if you have a running start - the speed drop will be acceptable. (2) For automated, a driver quickly brings the Prius up to a predetermine climbing speed (like 40 mph) and fixes this speed using the cruise control. The on board computer is then used to maintain the climbing speed until the Prius gets to the top of the hill at which time the driver turns off the cruise control and sets the throttle back to manual. This keeps the Prius speed up while using the least amount of fuel possible.
    OTH: A 1.5 mile commute is better served with an electric car like a Leaf, plug in car like the Plug in Prius, a human power vehicle (e.g. bicycle) if the roads allow for it, mass transit, or walking if the conditions permit it.
    #11 walter Lee, Jan 15, 2015
    capobvious likes this.
  12. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Bicycle the 1.5 miles!
    Free and healthy and prob just as quick as getting in the car and sitting at traffic lights. If it's chilly layer up and get the handlebar muffs. They work great.
  13. capobvious
    Asheville, NC
    well, the lease in my area was better for the base prius. The chevy dealer was not willing to budge for a 2000 dp, 369/mo lease. I don't know why, I didn't care to haggle, tried twice with them saying it was way over what I could do and they wouldn't move on the price. Wayyyy over that the national promo was at the time. I think it was advertised for about 199 or something. The prius on the other hand, a very high traffic toyota dealer here, gave me a deal with no money down 277/mo. 50 less than my previous car, and same economy, I just lost the backup camera and sunroof, no big deal.
    F8L likes this.
  14. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    we're starting to get some <40 MPG tanks, but I think its just life style change all tiny trips around town.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I missed the fact you are in NC. A lot of Chevy dealers outside of CA really don't push the Volt and are not in competition with dealers like Keyes or Rydell. Still, they quoted you a crazy price. Still, you got a solid car so whatever right? :)
  16. bisco
    51,155
    best lifestyle, even if it costs a few mpg's. time to get serious about a pip.;)
    F8L likes this.
  17. capobvious
    Asheville, NC
    yea totally! got 2 years left on this one, and already jonesing for a plug in, new volt looks sweet too!
    F8L likes this.
