Cruise control based on load not speed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Robsquatch, Aug 8, 2012.
  1. Robsquatch
    Robsquatch Junior Member
    29
    Orlando
    Not sure if this should be under the technical section but is there a way to modify the cruise control to be set to a position on the hsi and not based on the speed. After all it is all electronic.
    PriusCamper likes this.
  2. Robsquatch
    29
    Orlando
  3. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    I wish my 08 had that, I rarely use cruise on the highway because I have my foot on the go pedal in a very specific spot as to achieve great fuel economy. My speed fluctuates but I don't care.
  4. Robsquatch
    29
    Orlando
    Exactly my point. Staying in shm or gradually slowing on the hill and accelerating on the downside would be cake. Also less battery usage. It seems like a better and perhaps easier mod than putting a lift on a jeep. I'm sure I'm not the first to think about it and it's probable already been done somewhere.
  5. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    This would most likely be a software change. Almost no one is willing to contemplate fiddling with the software in a Prius (even if there were any easy way to do it, which there isn't). You best bet is convince Toyota to do it. You have my support for that.
  6. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    Or even better, you set top and bottom speed and car would pulse and glide for you :) Using only the most efficient pulse at a given speed.
  7. Robsquatch
    29
    Orlando
    After further research which I should have done first this topic has been hashed out a few times in the past. I still haven't found a mod that someone has done
  8. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    Yes!!! If only you could change some wires and have Cruise control focused on keeping a steady MPG rather than a steady speed... Yet another reason why we need open-source programming for cars! Of course without access to Toyota's source code, this most likely isn't gonna happen!
