Cruise Control - car keeps accelerating after releasing cruise lever
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Carolyn Belknap, Oct 26, 2017.
  1. Carolyn Belknap
    Carolyn Belknap New Member
    Half Moon Bay
    Three Touring
    Just got a 2017 Prius 3T. Manual says that to accelerate 1 mph while on cruise control push the lever up once; to accelerate more hold the lever in the up position. We've noticed with our car that the car keeps accelerating even after releasing the lever, until we tap the brakes - which is not what the manual says should happen.
    Anyone else see this? Seems potentially dangerous.
    Thanks
    Montgomery likes this.
    49,498
    welcome!
    the error is in holding the stalk up. the computer is registering mph increase faster than the car.
    best thing is to use the accelerator.
    this has been happening since the computer genius woz first noticed it and called the cops.
    the real problem is translating japanenglish in your brain.
    jerrymildred and RCO like this.
  3. fuzzy1
    10,170
    RCO likes this.
    49,498
    :p yup, some people are too smaht for their own good.
    RCO likes this.
  5. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Look at the speed the cruise control is set to, when you hold the speed lever, the speed number keeps going up, so hold it for five seconds at 30 mph and now it’s set at 45 mph
    If you touch it once it goes up 1mph, but if you hold it it increases fast, the car speeds slowly until it gets to the set speed.
    RCO and Prodigyplace like this.
  6. bisco
    49,498
    if it were a gto, it could keep up with the cc.;)
  7. Tideland Prius
    16,155
    I would re-read the section on the radar cruise control (vehicle-to-vehicle cruise control in the manual) again.
    If you look at the set speed on the 4.2" MID (it should be showing the DRCC with your car and 1, 2, or 3 bars in front. On the bottom left or bottom right, there's a speed; that's your set speed).
    What you did by holding up is increase the set speed. When you let go, it's still accelerating to match your set speed. On the older Prii, holding it would increment by 5mph so people were freaking out. I guess Toyota kept it to 1mph for safety.
    This operates differently from regular cruise control (constant speed cruise control in the manual) where you accelerate until you let go of the stalk.
    RCO likes this.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    With DRCC, you actually set it to the km/hr or MPH you want. For instance, if you join a road and are in traffic with a speed limit of 90km/hr, you wind the stalk up to 90:
    You could be driving at 50km/hr at the time, wind it up to 90, and it will accelerated to 90 unless a vehicle is in front driving slower, in which case it will sit in behind that car till you change lanes etc. If that car slows and you're still behind, your car will slow down even to a complete halt. To then resume when he drives off, you just touch the accelerator briefly, releasing it when your car starts moving - it will resume following the car in front.
    Works perfectly.
    krmcg and RCO like this.
  9. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    Yes the DRCC is a fantastic bit of kit. I use it in slow moving stop and go traffic too as it saves having to ride the brakes all the time. Why not let the car take the stress out of driving (y)
    RCO likes this.
  10. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    I'm now a convert and can't imagine driving without DRCC.. never thought I'd be saying that when I joined Prius Chat! :love:
    pilotgrrl, Harters and krmcg like this.
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Please take your car to your local authorized dealer.
  12. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    @Carolyn Belknap , before you go to the dealer, try again, but this time just tap the cruise control bar up with a quick flip. This would be more likely to succeed than a push, which could be held longer than is necessary resulting in the extra acceleration you had earlier. (y)
    krmcg likes this.
  13. alanclarkeau
    7,044
    7,584
    I think it's likely working as it should.
    But, the dealer's salesperson REALLY should have given instruction (or demonstration) on it's use before delivery - so checking with your salesperson wouldn't go astray.
    Harters, jerrymildred and krmcg like this.
  14. Tideland Prius
    16,155
    The 2018 Camry has two different versions of DRCC which is explicitly mentioned in the specification sheet and brochure. What are the chances the product advisors will remember the differences? (and which trim level has it?)
    RCO, fuzzy1 and bisco like this.
  15. Mendel Leisk
    38,728
    How do you activate "resume"?
    If you cancel cruise, and then tap up on the stalk once, is that resume? I don't use that function to speak of, but I'm thinking: won't that activate resume, try to haul you all the way back up to the previously set speed, fairly aggressively.
    Apologies if this has been said already, haven't read right through the thread.
    RCO likes this.
  16. bisco
    49,498
    no worries, neither has carolyn.:cool:
    RCO and Mendel Leisk like this.
  17. alanclarkeau
    7,044
    7,584
    Yes, it will resume, but "aggressively" isn't the word which comes to mind - more like "leisurely". Instead of touching the stalk, I almost always touch the accelerator and when the car starts moving, leave it to resume.
    RCO likes this.
  18. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Is that + button direction not also labeled "Resume" ??
    The tap to accelerate works as advertised ONLY if the cruise is already "set" and functioning.
    Otherwise it functions as "resume" and will accelerate to the previously used speed.
    RCO likes this.
  19. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
    Agreed. This is one place the Driving Mode selection makes a big difference.
    alanclarkeau and RCO like this.
  20. Tideland Prius
    16,155
    Tap up to resume
    It depends on the generation. Mine (3rd Gen) will accelerate aggressively. The Gen 4 is a lot smoother and less aggressive.
