cruise control issue on 5th day of ownership
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vaskinfan, Oct 31, 2010.
  1. vaskinfan
    vaskinfan Junior Member
    virginia
    Picked up my PriusV on Monday. Used cruise a few times throughout the week. On the way to work Saturday the cruise did not work for my wife. She would turn it on, set it, and nothing, Today,Sunday,she drove it and it worked fine. Anyone else having this issue ??
  2. GasSaving
    GasSaving Saves $1,000/yr on gas
    52
    Boston
    You need to get that fixed under warranty. The Prius is one of the most reliable cars on this little planet, so get the cruise fixed so you can get back to enjoying your Prius.
    48,969
    take it out yourself and try it a few hundred times. she might have been mistaken.:)
  4. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    Hint: The cruise control will not engage if the gear shift is in "B" instead of "D."
  5. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    When she presses the button at the end of the lever, does the cruise control indicator come on on the instrument panel?
    When she pushes down the lever does the SET indicator on the instrument panel come on?
    If yes to both, maybe she is following a car that is going slower than what the cruise control setting is. If the cruise is set to 50 (as shown inside the cruise control indicator window) and the car in front is going 40, she's gonna go 40. Or....maybe it's broken.
    FYI, I brought my Prius V in a few days after I bought it because I thought the DCC was broken. It was the Wozniak syndrome that got me.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    post deleted
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    He only has the nav pack, so it's only a dumb cruise.
  8. tumbleweed
    4,067
    687
    Eastern Oregon
    Right you are, thanks, I'll delete my post.
