Cruise control not working
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, May 24, 2017.
  1. franken1313
    franken1313 Member
    216
    27
    US
    I use cruise control a lot.
    All the time actually
    My cruise control
    Only works sometimes.
    Any thoughts?
    52,627
    could be the stock, clock spring, sensors, control unit, it's hard to say. you would probably have to do some serious electrical troubleshooting. maybe even the brake switch, i'm not sure.
    how many miles on her?
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You do know that Cruise Control does not work in B, right?
    You want to avoid B unless you are going downhill with over a 600 foot vertical drop.
  4. franken1313
    franken1313 Member
    216
    27
    US
    120k
  5. franken1313
    franken1313 Member
    216
    27
    US
    I never use B only D
  6. bisco
    52,627
    what percent of the time does it not work?
    uber2016 likes this.
  7. franken1313
    franken1313 Member
    216
    27
    US
    Half maybe more . Definitely if I've been driving for more than 30min
  8. bisco
    52,627
    i would like to think it's in the stalk, because that is where the wear takes place, but i have no idea. does any amount of fiddling with the button help?
  9. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Do all the other buttons on the steering wheel work? Specifically, check the AC recirc button, that's usually the first to go.
    jerrymildred likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Chances are, it's either the clock spring or the brake light switch. Brake light switch is an easy check. Andrew has a good idea on the clock spring.
  11. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Cruise control was spotty on my 2010. I found that if I pushed the stalk firmly toward the steering column and then pushed to engage it would work. I suspected a faulty clock-spring cable.
  12. franken1313
    franken1313 Member
    216
    27
    US
  13. andrewclaus
    993
    326
    Golden, CO
    That's an inverter pump failure code, a separate and much more critical problem. Do a search here for that, lots of advice on it.
  14. franken1313
    franken1313 Member
    216
    27
    US
    I've already changed the pumps countless times. It's something else
  15. bisco
    52,627
    how is your 12v health?
  16. franken1313
    franken1313 Member
    216
    27
    US
  17. KAR IDEA
    KAR IDEA Member
    465
    Lake Peekskill, NY USA
    Three Touring
    Any progress on this? My cruise hasn't worked correctly for over a year now. The trick I employ is to turn the car on, jam the button with a keyring store plastic rewards card, then before I go anywhere I turn the steering wheel all the way to the left, then slowly back to center. That usually gets the "cruise" to light up. At that point I remove the card so the button pops back out. Then once I'm on the road and want to engage cruise, I have to be on a curve so the steering wheel is clocked left, it's the only way to catch the cruise speed. So I've wanted to fix this for a long time now, but don't know where to begin.
  18. DonDNH
    1,711
    655
    Nashua, NH
    Four Touring
    I was able to get the CC to work on my 2010 V by pushing the stalk firmly in the direction of the steering wheel and then forward. This worked for over year before I traded it last summer
    There is a clock spring cable that is probably causing the problem. It is under the center of the steering wheel. There are videos on how to replace it.
  19. HaleDad
    HaleDad New Member
    Idaho
    I bought a 2005 Prius a couple months ago. Cruise is the only thing not working. I can get it to engage if I work the steering wheel which leads me to believe it's the clock spring. My question is, where do I find a reliable clock spring for a decent price. I see them online for anywhere from $39 to $399. Any recommendations?
  20. bisco
    52,627
    congrats and welcome!
    that may be an oxymoron. what is the best oem price you can find? beware chinese knockoffs, they have a high early failure rate.
    it's too much work to do twice.
    see @ChapmanF threads for first hand experience
